I was looking to control the gpio_12_csi_1 to interface camera on aquila carrier board, it doesn’t seem to change the state of pin. Is there anything I am missing to configure the gpio?
Himanshu
Himanshu
Hello Himanshu,
I’d be glad to help with configuring GPIO_12_CSI_1 on your Aquila carrier board! To provide the most accurate guidance, could you let me know:
You can get this information by running the tdx-info command on your device. For more details, see: Getting Device Information with Tdx-Info | Toradex Developer Center
Based on the Aquila Carrier Board Design Guide, GPIO_12_CSI_1 is described as “Reserved general-purpose IO for MIPI CSI_1 interface” and operates at 1.8V CMOS logic level (1)(2). This pin is specifically reserved for camera interface functionality.
For GPIO pins that are multiplexed with other functions (like CSI camera interfaces), you typically need to:
Once you provide your platform details, I can give you specific device tree overlay examples and pin configuration steps for your exact hardware setup.
Common platforms include:
torizon@aquila-am69-12594705:~$ sudo tdx-info
Kernel version: 6.6.129-7.6.0 #1-Torizon SMP PREEMPT Tue Mar 31 11:40:26 UTC 2026
Distro name: NAME=“Torizon OS”
Distro version: VERSION_ID=7.6.0-build.36
Distro variant: VARIANT=“Docker”
Toradex version: 0211 V1.1A
Processor arch: aarch64
Perfect! Now I can provide specific guidance for your Aquila AM69 setup running Torizon OS 7.6.0.
For GPIO_12_CSI_1 on the Aquila AM69, you’ll need to create a device tree overlay to properly configure the pin multiplexing from its default CSI camera function to GPIO mode.
Create a device tree overlay file (e.g., aquila-am69_gpio12_overlay.dts) to configure GPIO_12_CSI_1:
/dts-v1/;
/plugin/;
compatible = "toradex,aquila-am69";
fragment@0 {
target = <&main_pmx0>;
__overlay__ {
gpio12_pins: gpio12-pins {
pinctrl-single,pins = <
/* Configure GPIO_12_CSI_1 as GPIO */
/* You'll need to check the exact pin configuration */
fragment@1 {
target = <&main_gpio0>; /* Adjust based on actual GPIO bank */
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&gpio12_pins>;
gpio12_hog: gpio12-hog {
gpio-hog;
gpios = <12 0>; /* Adjust GPIO number and flags */
output-low; /* or output-high */
line-name = "GPIO_12_CSI_1";
First, clone the device tree repository for your Torizon version(1):
$ git clone -b toradex_ti-linux-6.6.y git://git.toradex.com/linux-toradex.git linux
$ git clone -b toradex_ti-linux-6.6.y git://git.toradex.com/device-tree-overlays.git device-trees
Then apply the overlay using TorizonCore Builder(1):
$ torizoncore-builder dto deploy --remote-host <your-ip> --remote-username torizon --remote-password torizon --force --reboot aquila-am69_gpio12_overlay.dts
After reboot, check if the overlay was applied successfully(1):
# ls /proc/device-tree/chosen/overlays/
# cat /proc/device-tree/chosen/overlays/aquila-am69_gpio12_overlay.dtbo
If the value is 0, the overlay was applied successfully(1).
Pin Multiplexing: GPIO_12_CSI_1 is likely multiplexed with camera functionality, so you may need to disable any CSI camera overlays that might conflict(1).
Exact Pin Configuration: You’ll need to verify the exact pin control settings and GPIO bank/number for GPIO_12_CSI_1 in the AM69 documentation.
Recovery Option: If the overlay breaks boot, you can disable overlays in U-Boot by setting skip_fdt_overlays=1(1).
For quick prototyping, you can also modify the overlays.txt file directly on the device(1), but this approach is only recommended for evaluation purposes.
The key is ensuring proper pin multiplexing configuration in your device tree overlay to switch the pin from its default CSI function to GPIO mode.
For below overlay file, I get below result
torizon@aquila-am69-:~$ sudo cat /sys/kernel/debug/gpio | grep 657
Password:
gpio-657 (AQUILA_B19 |regulator-camera-csi) out lo ACTIVE LOW
torizon@aquila-am69-:~$ sudo cat /sys/kernel/debug/regulator/regulator_summary | grep V_CSI
V_CSI 1 0 0 unknown 0mV 0mA 0mV 0mV
/dts-v1/;
/plugin/;
#include “k3-pinctrl.h”
compatible = “toradex,aquila-am69”;
fragment@0 {
__overlay__ {
pinctrl_gpio_12_csi_1: gpio-12-csi-1-pins {
J784S4_IOPAD(0x0c0, PIN_OUTPUT, 7)
fragment@1 {
target-path = "/";
__overlay__ {
regulator_camera_csi_1: regulator-camera-csi-1 {
compatible = "regulator-fixed";
regulator-name = "V_CSI";
pinctrl-0 = <&pinctrl_gpio_12_csi_1>;
gpio = <&main_gpio0 48 GPIO_ACTIVE_LOW>;
startup-delay-us = <5000>;
regulator-boot-on;
regulator-always-on;
}; What is going wrong?
@hdevi
After your exchange with Toradex AI, you provided more useful information that should help us investigate and resolve the issue.
Let me summarize what we know so far:
Could you please clarify the following?
