The error messages you are encountering during the torizoncore-builder build process suggest that there is an issue with the image.json file, which is a crucial part of the Toradex Easy Installer image configuration. Here are some potential reasons and solutions for the errors:
FileNotFoundError: This error indicates that the
image.jsonfile is missing from the specified directory (/storage/tezi/). Ensure that theimage.jsonfile is present in the correct directory. You might need to verify the path specified in yourtcbuild.yamlconfiguration file to ensure it points to the correct location of the Toradex Easy Installer image. -
No root file system content section found: This error suggests that the
image.jsonfile is present but does not contain the necessary root file system content section. You should check theimage.jsonfile to ensure it is correctly formatted and includes all mandatory properties, especially those related to the root file system. You can use an online JSON validator like jsonlint.com to validate the JSON structure.
To resolve these issues, you should:
- Verify the presence and correctness of the
image.jsonfile in the specified directory. - Ensure that the
tcbuild.yamlconfiguration file correctly references the location of the Toradex Easy Installer image. - Validate the JSON structure of the
image.jsonfile to ensure it complies with the required format and includes all necessary sections.
If the problem persists, consider reaching out to the Toradex TorizonCore support team with the provided stack trace for further assistance.
Install TorizonCore Builder file not found error (when working with device tree overlays).
