Get VF50 image version through ActiveSync?
Is there a way to programmatically get the WinCE6 image version on a Colibri VF50 through the USB ActiveSync connection? I am trying to determine if the image needs to be upgraded during our production process.
Thank you.
Jerry
There is no function to provide this but you could implement it on your own.
You could implement a DLL that has a function that will return version. Copy this DLL to device and use CeRapiInvoke() to call this function over active sync.
I hope this helps you solve your issue
You can call the function Sys_GetConfigInt() to query the parameter BspVersion. The function is part of the SysInfoLib.
So what Toradex library call would I use to get the image version in the DLL that gets loaded onto the device?
Thank you.
