We are using the BSP3.0LTS in combination with the mainline kernel 5.4.61. We noticed that the fw_printenv command fails with:
$ fw_printenv
Cannot open /dev/mmcblk0boot0: No such file or directory
We guess its because our Linux system defines the eMMC as mmc2 instead of mmc0 as u-boot and TEZI:
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk2p2 7.8G 1.9G 5.6G 25% /
devtmpfs 954M 0 954M 0% /dev
tmpfs 1008M 0 1008M 0% /dev/shm
tmpfs 1008M 73M 935M 8% /run
tmpfs 1008M 0 1008M 0% /sys/fs/cgroup
tmpfs 1008M 0 1008M 0% /tmp
tmpfs 1008M 28K 1008M 1% /var/volatile
This is the corresponding dmesg:
dmesg | grep mmc
[ 2.732056] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.737199] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.742357] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.747497] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.765907] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.771073] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.776214] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.781372] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.794830] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.800001] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.805142] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.810301] mmc0: Missing autocal timeout 1v8-pad drvs
[ 3.158160] mmc0: Missing autocal timeout 3v3-pad drvs
[ 3.163355] mmc0: Missing autocal timeout 3v3-pad drvs
[ 3.168498] mmc0: Missing autocal timeout 1v8-pad drvs
[ 3.173746] mmc0: Missing autocal timeout 1v8-pad drvs
[ 3.187570] mmc0: Invalid maximum block size, assuming 512 bytes
[ 3.364314] mmc0: Internal clock never stabilised.
[ 3.369135] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 3.375583] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 3.382095] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 3.388557] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 3.395041] mmc0: sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 3.401509] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 3.407970] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000401
[ 3.414506] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 3.420987] mmc0: sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 3.434147] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 3.444125] mmc0: sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f77
[ 3.450626] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 3.457082] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 3.463544] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 3.470069] mmc0: sdhci: Host ctl2: 0x00000000
[ 3.474537] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 3.481719] mmc0: sdhci: ============================================
[ 3.640402] mmc0: Internal clock never stabilised.
[ 3.645212] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 3.651705] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 3.658160] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 3.664625] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 3.671093] mmc0: sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 3.677553] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 3.684042] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000401
[ 3.690503] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 3.696950] mmc0: sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 3.703411] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 3.709873] mmc0: sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f77
[ 3.716317] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 3.722783] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 3.729293] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 3.735738] mmc0: sdhci: Host ctl2: 0x00000000
[ 3.740207] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 3.747342] mmc0: sdhci: ============================================
[ 3.767015] mmc0: SDHCI controller on 700b0000.sdhci [700b0000.sdhci] using ADMA 64-bit
[ 3.780619] mmc1: Missing autocal timeout 3v3-pad drvs
[ 3.785761] mmc1: Missing autocal timeout 3v3-pad drvs
[ 3.790919] mmc1: Missing autocal timeout 1v8-pad drvs
[ 3.796060] mmc1: Missing autocal timeout 1v8-pad drvs
[ 3.808442] mmc1: Invalid maximum block size, assuming 512 bytes
[ 3.849708] mmc1: SDHCI controller on 700b0400.sdhci [700b0400.sdhci] using ADMA 64-bit
[ 3.858308] mmc2: Missing autocal timeout 3v3-pad drvs
[ 3.863502] mmc2: Missing autocal timeout 3v3-pad drvs
[ 3.868643] mmc2: Missing autocal timeout 1v8-pad drvs
[ 3.873801] mmc2: Missing autocal timeout 1v8-pad drvs
[ 3.886030] mmc2: Invalid maximum block size, assuming 512 bytes
[ 3.919150] mmc2: SDHCI controller on 700b0600.sdhci [700b0600.sdhci] using ADMA 64-bit
[ 4.032273] mmc2: new HS200 MMC card at address 0001
[ 4.038968] mmcblk2: mmc2:0001 S0J56X 14.8 GiB
[ 4.044721] mmcblk2boot0: mmc2:0001 S0J56X partition 1 31.5 MiB
[ 4.051835] mmcblk2boot1: mmc2:0001 S0J56X partition 2 31.5 MiB
[ 4.058064] mmcblk2rpmb: mmc2:0001 S0J56X partition 3 4.00 MiB, chardev (247:0)
[ 4.069526] mmcblk2: p1 p2 p3
How can we fix this issue? The image was installed via TEZI and mmc0 was defined as installation target. Do we need to change the device tree somehow? Thanks in advance.
