FRAMOS FSM:GO Camera support for IMX95?
Hi there, I am setting up the IMX95 Verdin Mallow system now for evaluation. I would love to test this out with the FRAMOS FSM:GO camera range. I see these cameras already support the IMX8M Verdin Mallow system. Is there any plan at Toradex to develop support for these cameras on the IMX95 SoC too?
Kind regards,
Jack
I’d be glad to help! Could you let me know which OS and version you are using on your Verdin iMX95 system? (1) (2) (3)
Current FRAMOS FSM:GO Support Status
Currently, the FRAMOS FSM:GO optical sensor modules are officially supported on specific Toradex hardware platforms (1) (2) (3):
Supported Hardware Combinations
  • System on Module: Verdin iMX8M Plus (1) (2) (3)
  • Carrier Boards: Verdin Development Board, Mallow Carrier Board, and Dahlia Carrier Board (1) (2) (3)
Supported Verdin iMX8M Plus Variants
The following versions support the FSM:GO cameras (1):
  • 0070 - Verdin iMX8M Plus Quad 8GB WB IT
  • 0058 - Verdin iMX8M Plus Quad 4GB WB IT
  • 0063 - Verdin iMX8M Plus Quad 4GB IT
  • 0064 - Verdin iMX8M Plus Quad 2GB WB IT
Available Camera Models
The FSM:GO family includes (1):
  • FSM:GO IMX662 (2MP/2K optical sensor module)
  • FSM:GO IMX676 (12MP/1:1 format optical sensor module)
  • FSM:GO IMX678 (8MP/4K optical sensor module)
Verdin iMX95 Support
Based on the available documentation, there is no current official support mentioned for FRAMOS FSM:GO cameras on the Verdin iMX95 platform (4). The Verdin iMX95 is a newer module based on the NXP iMX95 SoC (4), and the camera integration documentation specifically lists only the Verdin iMX8M Plus variants as compatible (1).
Software Requirements
For supported platforms, camera integration requires adding a Yocto Project layer to images built on top of the Toradex Linux BSP, with BSP versions 7.0.0 and 7.1.0 supporting this layer (1). Torizon OS 7 supports these cameras starting from version 7.0.0 (1).
To get the most current information about potential Verdin iMX95 support plans or development timelines, you can use the tdx-info command to get detailed system information and check for any updates at Getting Device Information with Tdx-Info | Toradex Developer Center.
Hi @jacko!
Although I can’t provide an estimated timeline, this is currently under development.
Unfortunately, we do not currently have off-the-shelf support for FRAMOS cameras on the i.MX95 SoC.
If you need something specific regarding FSM:GO on iMX95, you may contact saleseurope@framos.com for an initial inquiry.
Best regards.
Hi Lucas,
Thanks so much, that is great information. I will contact the team via email.
Actually, I recently contacted FRAMOS one week ago. What they told me was (paraphrased): “We are not currently developing FSM:GO support for the IMX95. You will need to contact Toradex for information.”
My business is very interested in testing this camera setup as an early adopter. If it goes well, we will integrate the FSM:GO camera and the IMX95 compute module in our products.
Can we discuss further about your progress on developing FSM:GO camera support for the IMX95? Specifically we are interested in the IMX678 camera. If this discussion needs to happen over email, happy to do that as well.
