Flashing the yocto build images into toradex apalis imx6
Hello Experts,
Recently I built the yocto images for apalis imx6 board by referring the below link.
http://developer.toradex.com/knowledge-base/board-support-package/openembedded-(core)
repo init -u Index of /toradex-bsp-platform.git -b LinuxImageV2.7
repo sync
And got the following images generated but I want to know which binaries are required to flash my binaries into apalis imx6 board.
Apalis-iMX6_LXDE-Image_2.7b3-20170713.tar
Apalis-iMX6_LXDE-Image_2.7b3-20170713.tar.bz2
Apalis-iMX6_LXDE-Image.bootfs.tar
Apalis-iMX6_LXDE-Image.bootfs.tar.xz
Apalis-iMX6_LXDE-Image.rootfs.ext4
Apalis-iMX6_LXDE-Image.rootfs.manifest
Apalis-iMX6_LXDE-Image.rootfs.sdcard
Apalis-iMX6_LXDE-Image.rootfs.tar.xz
image.json
LXDE-Image-apalis-imx6.ext4
LXDE-Image-apalis-imx6.manifest
LXDE-Image-apalis-imx6.sdcard.gz
LXDE-Image-apalis-imx6.tar.xz
marketing.tar
modules--4.1-2.0.x-2.7.3-apalis-imx6-20170713024200.tgz
modules-apalis-imx6.tgz
prepare.sh
README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
SPL
SPL-apalis-imx6-2016.11-2.7.3-gitrf0e4149-spl-2016.11-2.7.3-gitrf0e4149
SPL-apalis-imx6-spl
SPL-spl
u-boot-apalis-imx6.imx
u-boot-apalis-imx6.imx-recover
u-boot-apalis-imx6.imx-spl
u-boot.imx
u-boot.imx-recover
u-boot.imx-spl
u-boot-recover-2016.11-2.7.3-gitrf0e4149.imx
u-boot-spl-2016.11-2.7.3-gitrf0e4149.imx
uImage
uImage--4.1-2.0.x-2.7.3-apalis-imx6-20170713024200.bin
uImage--4.1-2.0.x-2.7.3-imx6q-apalis-eval-20170713024200.dtb
uImage--4.1-2.0.x-2.7.3-imx6q-apalis-ixora-20170713024200.dtb
uImage--4.1-2.0.x-2.7.3-imx6q-apalis_v1_0-eval-20170713024200.dtb
uImage--4.1-2.0.x-2.7.3-imx6q-apalis_v1_0-ixora-20170713024200.dtb
uImage-apalis-imx6.bin
uImage-imx6q-apalis-eval.dtb
uImage-imx6q-apalis-ixora.dtb
uImage-imx6q-apalis_v1_0-eval.dtb
uImage-imx6q-apalis_v1_0-ixora.dtb
wrapup.sh
BTW, I have referred the following link and didn’t help because this commands are expecting different binary names which I didn’t get it from yocto build.
http://developer.toradex.com/knowledge-base/flashing-linux-on-imx6-modules
I don’t have the below files which seems needed for updating binaries from SD.
flash_blk.img
mbr.bin
boot.vfat
root.ext3-100 TO root.ext3-107
Here is the files I have from pre-built images and how can I generate the below files from yocto build ??
titus@develpc:~/Downloads/toradexImage/Apalis-iMX6_LXDE-Image_2.7.3$
titus@develpc:~/Downloads/toradexImage/Apalis-iMX6_LXDE-Image_2.7.3$ ls apalis-imx6_bin/
flash_blk.img
flash_blk.scr
flash_eth.img
flash_eth.scr
fwd_blk.img
fwd_blk.scr
fwd_eth.img
fwd_eth.scr
fwd_mmc.img
fwd_mmc.scr
mk-u-boot-scripts.sh
SPL
SPL-apalis-imx6-spl
SPL-spl
u-boot.imx
u-boot.imx-recover
u-boot.imx-spl
uImage
uImage--4.1-2.0.x-2.7.3-apalis-imx6-20170630231347.bin
uImage--4.1-2.0.x-2.7.3-imx6q-apalis-eval-20170630231347.dtb
uImage--4.1-2.0.x-2.7.3-imx6q-apalis-ixora-20170630231347.dtb
uImage--4.1-2.0.x-2.7.3-imx6q-apalis_v1_0-eval-20170630231347.dtb
uImage--4.1-2.0.x-2.7.3-imx6q-apalis_v1_0-ixora-20170630231347.dtb
Thanks for your help.
Titus S.
That depends whether or not you wish to use the legacy update method or the new Toradex Easy Installer:
http://developer.toradex.com/software/toradex-easy-installer
  1. Apalis-iMX6_LXDE-Image_2.7b3-20170713.tar
That one is for the Toradex Easy Installer
  1. Apalis-iMX6_LXDE-Image_2.7b3-20170713.tar.bz2
And number 2 is the legacy one containing an update.sh shell script which can generate all the specific files you are looking for.
Somehow i only get the .tar archive not the tar.bz2 one, do you know what could be the problem?
No.
As you’re question is not really a follow up to the original post, please ask a new question and give some more detail of what you did with what version of things, adding relevant console output and the likes.
