I have a Colibri Evaluation Board With T20 and I have successfully flashed it with “Colibri_T20_LinuxImageV2.3” downloaded from Toradex site. I am doing this over USB in Recovery mode by running ‘update.sh’ script without any Memory card or USB drive. So far OK.
I have installed a tool chain and deployed a Hello world application using eclipse IDE following the instructions in Toradex site.
Now I need to develop an application using Qt.
So I followed instructions on this page.
I have successfully built
$ bitbake -k meta-toolchain-qt5
and installed QT and created a small form and it is running in my development machine also.
Now I need linux images for T20 with QT runtime files. (correct me if I am wrong).
So I built following successfully.
$ bitbake -k angstrom-lxde-image
$ bitbake -k console-trdx-image
I got folders what I believe contains images for T20
‘Colibri_T20_LinuxConsoleImageV2.6’ and ‘Colibri_T20_LinuxImageV2.6’
I tried to run the update.sh script in this folder as I have done in version 2.3 with T20 in recovery mode. but it seems something different here.
I got the following output
Prepares and copies files for flashing internal eMMC/NAND of Apalis T30/TK1 and
Colibri T20/T30
Will require a running U-Boot on the target. Either one already flashed on the
eMMC/NAND or one copied over USB into the module's RAM
-b : T20: selects boot device (hsmmc/nand) (default: nand)
-c : split resulting rootfs into chunks usable for TFTP transmission
-d : use USB recovery mode to copy/execute U-Boot to/from module's RAM
-f : flash instructions
-h : prints this message
-m : module type: 0: autodetect from ./rootfs/etc/issues (default)
1: Apalis T30
2: Apalis TK1
3: Colibri T20
4: Colibri T30
-o directory : output directory
-r : T20 recovery mode: select RAM size (256 | 512)
-s : T20: optimise file system for V1.1 or 256MB V1.2 modules,
increases usable space a little, but limits 512MB V1.2 modules
to 512MB usable NAND space
-v : T20 recovery mode: select Colibri version (V1_1 | V1_2)
Example "./update.sh -o /srv/tftp/" copies the required files to /srv/tftp/
*** For detailed recovery/update procedures, refer to the following website: ***
http://developer.toradex.com/knowledge-base/flashing-linux-on-tegra-modules
I tried by changing arguments also. but it seems not the correct way.
Please help
I can access uboot console via cutcom and see the kernel messages as well as login after booting in 2.3 image.
