We want to flash our IMX6ULL 512MB Wi-Fi / Bluetooth IT Board using the TEZI installer.
Our Partition Layout is a classic A/B/DATA layout which requires 3 partitions to be written.
- A / B both should be flashed with our rootfs image.
- DATA can be kept empty, we will mount it into /home later
Now we are writing an image.json and are hesitant about some of the details:
- We assume that the usual mmcblk0 Is missing for our BoardType stated to be equipped with SLC NAND
- We also assume that all our planned partitions should be installed in the ubi volume at the end of NAND
- Our Plan would be to create our A/B/DATA ubi-volumes using
ubicreate
and fitting ?byte?-offsets for each of them [1] - We assume we have to flash the volumes u-boot1 AND u-boot2 with a uboot created by yocto - our yocto creates a file called
u-boot-nand.imx
which we assume needs to be flashed to u-boot1 and u-boot2 (in all toradex images, however, the file is called u-boot.imx-rawnand and we dont know if its the same file-format)
We would be really happy if you could confirm the points 1.-4. above, and – if not– could correct us on our assumptions.
[1] How to make partitions on SLC NAND flash which uses ubifs? - #3 by stefan.tx
