Hi all,
Trying to flash Image into SD card but its failed.I do have colibri T30 Board with Iris V1.1A;also i have attached screenshot of that issue .
Dear @hanmant9096,
Thank you for contacting Toradex Support!
Please go through the following link for the step-by-step procedure of flashing an Image into SD-card with Iris carrier board.
Thank you and Regards,
Janani
I unable make Partitions of SD Cards.
What have you done?
Could you share the commands and the error log in text format?
Thanks and best regards,
