There is a note in the docs:
Warning: V2.7 Beta 1 release suffers a bug which does not allow to use an USB flash drive for flashing.
Has this been resolved? Does the issue continue above Beta 1?
I was using 2.7 and had an issue creating the USB Drive. I edited the update.sh and got it to work.
sudo cp ${BINARIES}/u-boot-nand.imx ${BINARIES}/zImage ${BINARIES}/ubifs.img ${BINARIES}/flash*.img ${BINARIES}/versions.txt "$OUT_DIR"
sudo cp ${BINARIES}/fwd_blk.img "$OUT_DIR/../flash_blk.imgZZZ"
It seems adding the ZZZ to the end of the file name on the second line fixed it. I had to rename later.
