Flashimage error for VF61 V1.2A
I have followed the following URL for recovery mode,
http://developer.toradex.com/knowledge-base/colibri-vf50-vf61-wince-bring-up#Flashing_from_recovery_mode_fused_modules
I am getting an error while executing command “flashimage nk6.bin”. The error is as follows,
“Error reading block 5” and “Error saving config”.
This might happen if the versions of the bootloader, OS and config block don’t match.
Please try to wipe and re-create the config block as described in the developer page article you mentioned above:
>eraseflash 0 128kb
>writebcb
>restorefactoryinfo VF61256 04790168 1.0B
In the commands above you need to replace the serial number 04790168 and version 1.0B with the actual values printed on your module’s barcode label.
Duplicates https://www.toradex.com/community/questions/17419/colibri-vf-61-not-booting-after-os-update.html
Done with eraseflash, writebcb, restorefactory, and finally flashloader. As mentioned in above article, if we are executing command >flashloader, It will erase the blocks 1,2 and 3.
But in my device it is erasing only 1st and 2nd blocks.
Does it related to the problem what I am facing?
Done with eraseflash, writebcb, restorefactory, and finally flashloader. As mentioned in above article, if we are executing command >flashloader, It will erase the blocks 1,2 and 3. But in my device it is erasing only 1st and 2nd blocks. Does it related to the problem what I am facing?
The number of erased blocks depends on the location and the process used to write the loader, this is not an error.
