Fastest Way to Communicate between Container and MCU
Hi @rudhi.tx
Would it be possible to schedule a meeting with a support engineer to get this working? The interaction via forum is very slow and meanwhile the thread is quite long.
I cannot get it working on my board.
Hello @chalu,
I will send you a private message to talk about scheduling a meeting.
Hello @chalu,
I hope the issues you were facing related to this thread were solved after your meeting with @henrique.tx and @hfranco.tx. Please let me know if there is anything else that we could help you with here.
hi @rudhi.tx
the meeting was super helpful and is likely solved. i will post the testing results here once i have them.
i think for now we can close it.
thank you
Hi @chalu ,
hi @rudhi.tx
can you provide details on how you’ve been able to use shared memory on Verdin iMX8M-Plus?
Hello @vix,
You should be able to test it using the sample code given by @hfranco.tx here and if you apply the overlay for RPMsg. Are you facing any issues there? Could you please share more details about what you have tried?
Hi @rudhi.tx
I’m in touch with Toradex support through private message (Ticket#2024051510000319 in case you’re interested).
I described there what is my issue (basically devmem2 doesn’t work on Torizon OS) and I was curious about how @chalu solved.
Hello @vix,
Thank you, I will follow up with your discussion there.
