I would like to compile Nouveau BSP to test wayland on Apalis TK1. Everything is ok until running ‘./scripts/build-pthread-stubs’ according the article on developer center. This is the error:
ben@ben-HP:~/toradex/apalis/k1/tegra-nouveau-rootfs_1$ ./scripts/build-pthread-stubs
scripts/env.sh: line 68: /home/ben/toradex/apalis/k1/tegra-nouveau-rootfs_1/pthread-stubs/autogen.sh: no such file or directory
It is the same with ‘./scripts/build-drm’.
There is not folder ‘pthread-stubs’ or ‘$BUILDROOT/$PACKAGE/Makefile’
ben@ben-HP:~/toradex/apalis/k1/tegra-nouveau-rootfs_1$ ls
kmscube linux linux-firmware mesa nouveau out pkg-config-0.29.1 scripts
ben@ben-HP:~/toradex/apalis/k1/tegra-nouveau-rootfs_1$ ls out/build/arm/ArchLinuxArm/pthread-stubs
