Failed to build angstrom-qt5-x11-image recipe on Colibri-T20 with Yocto/Poky
Hi
I guess that poky does more stringent tests than angstrom as I’m able to build angstrom-qt5-x11-image with the V2.6.1 layer versions.
Unless you really need the trdx-nv-binaries-nv-gstapps which contains CLI tools for playing and recording videos I would propose to remove that package from your image.
e.g. in local.conf:
IMAGE_INSTALL_remove_append = " trdx-nv-binaries-nv-gstapps"
Otherwise you would need to fix this.
Probably one could move the creation of the /usr/lib/libpcre*.so.3 symlinks to the relevant pcre recipes.
No, we do not provide a prebuilt angstrom-qt5-x11-image, not even one built from our regular angstrom setup.
Max
