Failed installation of PyQtChart on Python QML project
Hi sirs.
I am still in the process of evaluating the GUI support for applications on the Torizon platform.
This time I was able to run and debug a Python QML application on the device.
I then wanted to add a sample chart to my GUI.
I added the line “import QtCharts 2.0” to my QML file, but execution fails stating that QtCharts is not installed. That’s fine. As a test, I logged in my container and run “pip3 install PyQtChart”, the procedure starts correctly but in the end it fails while installing the SIP dependency. Any hint? Thanks
My configuration:
  • Colibri iMX6DL 512MB v1.1Y
  • Iris V2.0A
  • TorizonCore Upstream 5.6.0+build.13 (dunfell)
  • Toradex Torizon Support v1.4.0
Here’s the pip3 log:
torizon@be84081b237d:/usr/bin$ pip3 install PyQtChart
Defaulting to user installation because normal site-packages is not writeable
Collecting PyQtChart
  Using cached PyQtChart-5.15.6.tar.gz (68 kB)
  Installing build dependencies ... error
  error: subprocess-exited-with-error
  × pip subprocess to install build dependencies did not run successfully.
  │ exit code: 1
  ╰─> [144 lines of output]
      Collecting sip<7,>=5.3
        Using cached sip-6.6.2.tar.gz (1.1 MB)
        Installing build dependencies: started
        Installing build dependencies: finished with status 'done'
        Getting requirements to build wheel: started
        Getting requirements to build wheel: finished with status 'done'
        Preparing metadata (pyproject.toml): started
        Preparing metadata (pyproject.toml): finished with status 'done'
      Collecting PyQt-builder<2,>=1.9
        Using cached PyQt_builder-1.13.0-py3-none-any.whl (3.7 MB)
      Collecting ply
        Using cached ply-3.11-py2.py3-none-any.whl (49 kB)
      Collecting toml
        Using cached toml-0.10.2-py2.py3-none-any.whl (16 kB)
      Collecting setuptools
        Using cached setuptools-63.1.0-py3-none-any.whl (1.2 MB)
      Collecting packaging
        Using cached packaging-21.3-py3-none-any.whl (40 kB)
      Collecting pyparsing!=3.0.5,>=2.0.2
        Using cached pyparsing-3.0.9-py3-none-any.whl (98 kB)
      Building wheels for collected packages: sip
        Building wheel for sip (pyproject.toml): started
        Building wheel for sip (pyproject.toml): finished with status 'error'
        × Building wheel for sip (pyproject.toml) did not run successfully.
        │ exit code: 1
        ╰─> [110 lines of output]
            running bdist_wheel
            running build
            running build_py
            creating build
            creating build/lib.linux-armv7l-cpython-39
            creating build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/version.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/setuptools_builder.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/pyproject.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/py_versions.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/project.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/installable.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/exceptions.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/distutils_builder.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/configurable.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/builder.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/buildable.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/bindings_configuration.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/bindings.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/argument_parser.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/api.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/abstract_project.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/abstract_builder.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            copying sipbuild/__init__.py -> build/lib.linux-armv7l-cpython-39/sipbuild
            creating build/lib.linux-armv7l-cpython-39/sipbuild/tools
            copying sipbuild/tools/wheel.py -> build/lib.linux-armv7l-cpython-39/sipbuild/tools
            copying sipbuild/tools/sdist.py -> build/lib.linux-armv7l-cpython-39/sipbuild/tools
            copying sipbuild/tools/install.py -> build/lib.linux-armv7l-cpython-39/sipbuild/tools
            copying sipbuild/tools/build.py -> build/lib.linux-armv7l-cpython-39/sipbuild/tools
            copying sipbuild/tools/__init__.py -> build/lib.linux-armv7l-cpython-39/sipbuild/tools
            creating build/lib.linux-armv7l-cpython-39/sipbuild/module
            copying sipbuild/module/module.py -> build/lib.linux-armv7l-cpython-39/sipbuild/module
            copying sipbuild/module/main.py -> build/lib.linux-armv7l-cpython-39/sipbuild/module
            copying sipbuild/module/abi_version.py -> build/lib.linux-armv7l-cpython-39/sipbuild/module
            copying sipbuild/module/__init__.py -> build/lib.linux-armv7l-cpython-39/sipbuild/module
            creating build/lib.linux-armv7l-cpython-39/sipbuild/generator
            copying sipbuild/generator/utils.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator
            copying sipbuild/generator/templates.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator
            copying sipbuild/generator/specification.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator
            copying sipbuild/generator/python_slots.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator
            copying sipbuild/generator/__init__.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator
            creating build/lib.linux-armv7l-cpython-39/sipbuild/distinfo
            copying sipbuild/distinfo/main.py -> build/lib.linux-armv7l-cpython-39/sipbuild/distinfo
            copying sipbuild/distinfo/distinfo.py -> build/lib.linux-armv7l-cpython-39/sipbuild/distinfo
            copying sipbuild/distinfo/__init__.py -> build/lib.linux-armv7l-cpython-39/sipbuild/distinfo
            creating build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/tokens.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/rules.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/python_exceptions.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/parsetab.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/parser_manager.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/parser.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/instantiations.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/annotations.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            copying sipbuild/generator/parser/__init__.py -> build/lib.linux-armv7l-cpython-39/sipbuild/generator/parser
            creating build/lib.linux-armv7l-cpython-39/sipbuild/module/source
            creating build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_voidptr.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_threads.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_object_map.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_int_convertors.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_enum.h -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_enum.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_descriptors.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_core.h -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_core.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_bool.cpp -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_array.h -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip_array.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip.rst.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip.pyi -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/sip.h.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/setup.py.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/setup.cfg.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/pyproject.toml -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/README.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/MANIFEST.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/LICENSE-GPL3 -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/LICENSE-GPL2 -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            copying sipbuild/module/source/13/LICENSE -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/13
            creating build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/voidptr.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/threads.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/siplib.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/sipint.h -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/sip_array.h -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/sip_array.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/sip.rst.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/sip.pyi -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/sip.h.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/setup.py.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/setup.cfg.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/qtlib.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/pyproject.toml -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/objmap.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/int_convertors.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/descriptors.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/bool.cpp -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/apiversions.c -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/README.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/MANIFEST.in -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/LICENSE-GPL3 -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/LICENSE-GPL2 -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            copying sipbuild/module/source/12/LICENSE -> build/lib.linux-armv7l-cpython-39/sipbuild/module/source/12
            running build_ext
            building 'sipbuild.code_generator' extension
            creating build/temp.linux-armv7l-cpython-39
            creating build/temp.linux-armv7l-cpython-39/code_generator
            arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-jS0VHk/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -Icode_generator -I/usr/include/python3.9 -c code_generator/export.c -o build/temp.linux-armv7l-cpython-39/code_generator/export.o
            error: command 'arm-linux-gnueabihf-gcc' failed: No such file or directory
            [end of output]
        note: This error originates from a subprocess, and is likely not a problem with pip.
        ERROR: Failed building wheel for sip
      Failed to build sip
      ERROR: Could not build wheels for sip, which is required to install pyproject.toml-based projects
      [end of output]
│ exit code: 1
╰─> See above for output.
This is the complete log when I add “pip3 install PyQtChart” to my setup.sh file and hit F5
log.txt (52.0 KB)
Hi @Lorenzo ,
You can install QtCharts via the Debian Feeds using the extrapackages configuration, as described here: Python Development and Debugging on TorizonCore Using Visual Studio Code | Toradex Developer Center. Just replace the package name with qml-module-qtcharts, press F5 and it should work.
Let me know if this helps you.
Lucas Akira
Thanks, Lucas, it’s working.
Lorenzo
Glad that worked for you!
Lucas Akira
