We tried both available installers 2.0b4 and 2.0b6 on Win 10. PC provides the following messages:
2664-after-that-tezi-does-not-start.docx (55.7 KB)
Could you please set up a debug serial port connection with Colibri and capture a log file during recovery procedure?
Could you please try:
While loading Toradex Easy Installer over USB press “space” at debug terminal window to stop loading at U_boot stage.
Then issue
env default -a
saveenv
Reset module and try to load Toradex Easy Installer again.
