Thank you for contacting support.
Did you see the same issue on Colibri Eval Board?
Could you please probe the I2C SCL, SDA lines using Oscilloscope and share the waveform?
In rare cases, if you experience I2C failures of Vybrid Modules, reducing pull-up resistor value may be of valuable help. 1.8K pull-up can give the better result.
