Hello @ferranmc,
I was able to test this on BSP 7 and the call worked without issues.
The build used the Toradex Reference Multimedia Image 7.0.0 as a base, with the following additions to local.conf:
ACCEPT_FSL_EULA = "1"
IMAGE_INSTALL:append = " pulseaudio-server pulseaudio-module-loopback pulseaudio-module-bluez5-discover pulseaudio-module-bluetooth-discover pulseaudio-module-bluetooth-policy pulseaudio-module-bluez5-device pulseaudio-module-cli pulseaudio-module-echo-cancel ofono pulseaudio pulseaudio-misc webrtc-audio-processing"
DISTRO_FEATURES:append = " pulseaudio"
After the image is built and installed to the module, you can run the following script to setup the Bluetooth communication:
#!/bin/bash
# to check if PulseAudio is running
check_pulseaudio() {
ps aux | grep -i pulseaudio | grep -v grep > /dev/null
return $?
echo "Killing and unblocking bluetooth"
rfkill unblock bluetooth
sleep 1
echo "Powering bluetooth"
bluetoothctl power on
echo "Turn on agent"
bluetoothctl agent on
sleep 1
echo "setting default agent"
bluetoothctl default-agent
# Check for PulseAudio processes
process_id=$(ps aux | grep -i pulseaudio | grep -v grep | awk '{print $2}')
# If a PulseAudio process is found
if [ ! -z "$process_id" ]; then
echo "PulseAudio process found with PID: $process_id"
# Kill the PulseAudio process
kill -9 $process_id
# Verify if the process is killed
if [ $? -eq 0 ]; then
echo "PulseAudio process killed successfully."
else
echo "Failed to kill the PulseAudio process."
fi
else
echo "No PulseAudio process found."
fi
echo "starting Pulseaudio"
pulseaudio --start
# Wait for PulseAudio process to start
while ! check_pulseaudio; do
echo "Waiting for PulseAudio to start..."
sleep 1
done
echo "PulseAudio is now running."
echo "Loading sink/output device"
pactl load-module module-alsa-sink device=hw:0,0
sleep 1
echo "Setting default sink/output"
pactl set-default-sink alsa_output.hw_0_0
echo "Loading source/input"
pactl load-module module-alsa-source device=hw:0,0
echo "Setting default source/input"
pactl set-default-source alsa_input.hw_0_0
echo "Enabling SCO "
hcitool -i hci0 cmd 0x3F 0x001D 0x00
echo "Device ready to connect/pair"
Then, using bluetoothctl:
- Pair to the phone
- Trust the phone
- Connect to the phone
At this point, calls from the phone should use the audio from the module as expected.
Can you give this a try and let me know how it goes for you?
Bruno
