Ethernet interface issue with WINCE8 since apalis IMX6Q V1.1D
I recently received apalis IMX6Q V1.1D boards and installed WINCE8 on them to run a C# application. With all apalis IMX6Q V1.1D boards, I have a network problem regarding the ENET1 interface. Running ipconfig, I get the following output message:
The ethernet interface shows me: media disconnected. I have never encountered this problem before with the apalis IMX6Q V1.1B cards I have worked with.
I should mention that I am using the latest version of WINCE8 (1.6, build 6270) on both types of cards and that the problem occurs before I install my application on the card. Has anyone encountered this problem before? Is there a way to fix it?
eiffonck
Could you please specify carrier board you are using and its HW revision?
I tested it with an Apalis Evaluation Board Rev. 1.1A and a custom board designed by my company.
I meet the issue with both boards.
Actually the latest WEC2013 BSP release is 1.8. Could you try it please?
Support for the new KSZ9131RNX Ethernet Phy Chip installed on 1.1D revision was introduced at 1.7 BSP version.
Thank you for your reply.
The issue is that the leatest TEZI images provided on the section “Toradex Windows Embedded Compact Images” of this webpage: Toradex Download Links (Torizon, Linux BSP, WinCE and Partner Demos) | Toradex Developer Center are on the version 1.6.
Since I am working offline I must access a tezi image of wince 1.8. Do you know where I can get it ?
eiffonck
For offline update you can use the Update Tool and image provided by this link.
Thank you.
Don’t you have any Toradex easy installer version of this image? It would simplify my installation process to install first the good image and reduce the number of operations to perform on the board.
if it helps anyone else, I found it online:
http://tezi.toradex.com/artifactory/legacy-oe-prod-frankfurt/iMX6_WinCE8Image-Tezi_1.8-20220622/
