I am configuring a Colibri iMX8QXP 2GB WB V1.0D on the Colibri Evaluation Board V3.2 using TorizonCore 5.7.0 (torizon-core-docker-colibri-imx8x-Tezi_5.7.0+build.17).
I got the following errors:
[ 0.133992] No BMan portals available!
[ 0.135191] No QMan portals available!
[ 1.530443] imx8qxp-lpcg-clk 37620000.clock-controller: failed to get clock parent names
[ 1.711078] mxsfb 5a180000.lcdif: Failed to create outputs
[ 2.033108] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 2.146151] debugfs: Directory '59040000.sai' with parent 'imx8qxp-sgtl5000' already present!
[ 15.402012] Bluetooth: hci0: unexpected event for opcode 0x0000
System information:
torizon@colibri-imx8x-07252168:~$ uname -a
Linux colibri-imx8x-07252168 5.4.193-5.7.0+git.f78299297185 #1-TorizonCore SMP PREEMPT Mon Jul 11 14:42:03 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
Attached the full output of the kernel buffer:
dmesg_output (33.7 KB)
I tried using torizoncore-builder to build and deploy the image.
My tcbuild.yaml file:
input:
easy-installer:
local: input_image/
customization:
device-tree:
include-dirs:
- device-trees/include/
custom: device-trees/dts-arm64/imx8qxp-colibri-eval-v3.dts
output:
easy-installer:
local: custom_image/
Same results, I was not able to solve these errors.
Any help will be appreciated.
