Got stuck in an error while building the toolchain using "bitbake -k meta-toolchain-qt5". I had already build the image as given in “High performance, low power Embedded Computing Systems | Toradex Developer Center”. But after this on doing the further process as per “How to set up Qt Creator to cross compile for embedded Linux | Toradex Developer Center” there shows the error as given in the attachment. Could anyone please give me any solution.
Which version of the BSP are you using?
How can i find the BSP version?? I’m using LinuxImageV2.6
Hi
Update meta-qt5 to HEAD of jethro-next, i.e. to a8d4dafdfde812e403315d53b2a981d12bd49f04.
Or alternatively update the BSP to at least 2.6.1.
Max
