Board: Apalis iMX8 on a custom carrier board
I’m following the instructions from Device Tree Overlays on Torizon | Toradex Developer Center
and have done the the tcb-env-setup.sh and then an images unpack which generates an error:
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
Traceback (most recent call last):
File "/builder/torizoncore-builder", line 215, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/images.py", line 399, in do_images_unpack
images_unpack(args.image_directory,
File "/builder/tcbuilder/cli/images.py", line 393, in images_unpack
images.import_local_image(image_dir, dir_list[0], dir_list[1], dir_list[2])
File "/builder/tcbuilder/backend/images.py", line 295, in import_local_image
subprocess.check_output(tarcmd, shell=True, stderr=subprocess.STDOUT)
File "/usr/lib/python3.9/subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'cat /workdir/torizon-core-docker-apalis-imx8-Tezi_5.5.0+build.11.tar | cat | tar -xf - -C /storage/tezi.tmp' returned non-zero exit status 2.
Here’s a full trace of what I did
john@John:~/tcbworkdir$ source tcb-env-setup.sh -- -p 8080:8080
You may have an outdated version installed. Would you like to check for updates online? [y/n] y
Setting up TorizonCore Builder with version 3.
Pulling TorizonCore Builder...
3: Pulling from torizon/torizoncore-builder
Digest: sha256:3d796d6ede4dde94ccd8ada7594d569be6e2bf765465260ce1163da997993b76
Status: Image is up to date for torizon/torizoncore-builder:3
docker.io/torizon/torizoncore-builder:3
Done!
Setup complete! TorizonCore Builder is now ready to use.
TorizonCore Builder internal status and image customizations will be stored in Docker volume named 'storage'.
Important: When you run TorizonCore Builder, the tool can only access the files inside the current working directory. Files and directories outside of the current working directory, or links to files and directories outside of the current working directory, won't be visible to TorizonCore Builder. So please make sure that, when running TorizonCore Builder, all files and directories passed as parameters are within the current working directory.
Your current working directory is: /home/john/tcbworkdir
For more information, run 'torizoncore-builder -h' or go to https://developer.toradex.com/knowledge-base/torizoncore-builder-tool
john@John:~/tcbworkdir$ torizoncore-builder images unpack torizon-core-docker-apalis-imx8-Tezi_5.5.0+build.11.tar
Storage not empty. Delete current image before continuing? [y/N] y
Unpacking Toradex Easy Installer image.
