Error when trying to compile kernel for Colibri iMX6
I’ve been going through the instructions on the Build U-Boot and Linux Kernel from Source Code page and I got the following errors when trying to compile the Kernel.
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  CHK     kernel/config_data.h
  Kernel: arch/arm/boot/Image is ready
  LZO     arch/arm/boot/compressed/piggy.lzo
/bin/sh: 1: lzop: not found
make[2]: *** [arch/arm/boot/compressed/piggy.lzo] Error 1
make[1]: *** [arch/arm/boot/compressed/vmlinux] Error 2
make: *** [uImage] Error 2
make: INTERNAL: Exiting with 4 jobserver tokens available; should be 3!
I’m sure I missed a step but I’m not exactly sure where.
Suggestions? Thanks.
Which distribution do you use? Can you check by installing the lzop package using the package manager.
