[ ERROR :: try-update-template failed with exit code 1] - VS Code IDE Extension Issue Report (c5e80ebddfbebd0a7cfe77394ae5547d)
OS: linux :: x64
Distro: Debian GNU/Linux 12 (bookworm)
Extension activation logs:
 Activating Torizon IDE ...
 Telemetry is enabled
 Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
 Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
 Resolving host IP address ...
 Host IP address OK
 Docker installed OK
 Docker running OK
 Docker compose OK
 PowerShell OK
 git OK
[01-19 10:34:37.09] dig OK
 avahi-resolve OK
 nmap OK
 iputils-ping OK
 file OK
 sshpass OK
 net-tools OK
 Cloning project templates
 ERROR :: Error trying to clone application templates
 Schwerwiegend: Zielpfad '/home/alazaj/.apollox' existiert bereits und ist kein leeres Verzeichnis.
 Checking connected devices ...
 Scanning Torizon devices ...
 Configuring debug id_rsa ...
 Debug id_rsa OK
 Torizon IDE extension activated
 Checking host ip sanity ...
 Debian bookworm packages list load OK
 Host ip is OK
 Device 192.168.79.129 set as Docker Host
Tasks logs:
 *  Executing task: echo echo 'Templates repo fetched!'
echo Templates repo fetched!
Get-Content: /home/alazaj/releaseDemo/.conf/projectUpdater.ps1:69:17
Line |
  69 |  $templateName = Get-Content $projectFolder/.conf/.template
     | Cannot find path '/home/alazaj/releaseDemo/.conf/.template' because it does not exist.
 *  The terminal process "pwsh '-nop', '/home/alazaj/releaseDemo/.conf/projectUpdater.ps1', '/home/alazaj/releaseDemo', 'releaseDemo', '0'" terminated with exit code: 1.
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
Seems like the extension tries to create /home/alazaj/.apollox, but this already exists for some reason. Could you try deleting this and trying again.
