I’m using Torizon with VS2019 following your guide.
I got an error 529 during “Deloy and debug Torizon application”. I’ve already checked the firewall settings for moses.exe and made sure that the board and my pc are in the same network. Below the output from Torizon Build.
Any ideas what could be wrong?
Thanks, Holger
Backend service and docker are up and running, enabling Torizon features.
Deployment started…
Loading application configuration…
Device is not configured in project properties, prompting user to select a device.
Checking container state…
Deploying and starting remote container (it may take some time after a build or the first time you connect to a device)…
Configuring project…
Error synchronizing folders from SDK container to target application. If you restarted the SDK container (or rebooted your machine) you may need to to a rebuild of the application before deploying and debugging it on the target.
Code: 529
Description: Remote command execution failed.
Message: Remote command rsync -rzv -e “ssh -p 32770 -o "StrictHostKeyChecking no"” ~//EcMasterDemo/* torizon@172.17.10.50:~//EcMasterDemo returned error 255
