[Error response from daemon: No such container: binfmt] - VS Code IDE Extension Issue Report (542d692143b6bf32620d345959781f8d)
OS: linux :: x64
Distro: Debian GNU/Linux 12 (bookworm)
Extension activation logs:
 Activating Torizon IDE ...
 Telemetry is enabled
 Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
 Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
 User defined host IP address found
 Host IP address OK
 Docker installed OK
 Docker running OK
 Docker compose OK
 PowerShell OK
 git OK
 dig OK
 avahi-resolve OK
 nmap OK
 iputils-ping OK
 file OK
 sshpass OK
 net-tools OK
 Cloning project templates
 Project templates clone OK
 Project templates fetched OK
 Checkout templates repo to v2.3.2 OK
 Checking connected devices ...
 Scanning Torizon devices ...
 Configuring debug id_rsa ...
 Debug id_rsa OK
 Torizon IDE extension activated
 WARNING :: Device not reached! Please check if the device is turned on and connected to the network.
 ERROR :: 10.12.0.239 not reached
 Debian bookworm packages list load OK
 ERROR :: validate-deps-running failed with exit code 69
Tasks logs:
Container Runtime: docker
Run Arguments: --rm --privileged torizon/binfmt
Container Name: binfmt
Container does not exists. Starting ...
 *  Executing task in folder FSP_System: pwsh .conf/validateDepsRunning.ps1
儭 VALIDATING ENVIRONMENT
 Missing settings.json properties, aborting
儭  Did you forget to set default device?
If you are facing issues even after setting default device, please remove the registered device and connect it again.
 *  The terminal process "pwsh '.conf/validateDepsRunning.ps1'" terminated with exit code: 69.
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
Strange for some reason it appears to fail to run the torizon/binfmt container. Well the container image does exist here: Docker
Perhaps theres something wrong with your docker setup? Its hard to say without more information.
