[ ERROR :: pull-container-torizon-debug-arm64 failed with exit code 1] - VS Code IDE Extension Issue Report (6095241cd8939ac80d44c5ebfffb2ffc)
OS: linux :: x64
Distro: Ubuntu 22.04.3 LTS
Extension activation logs:
 Activating Torizon IDE ...
 Telemetry is enabled
 Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
 Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
 Resolving host IP address ...
 Host IP address OK
 Docker installed OK
 Docker running OK
 Docker compose OK
 PowerShell OK
 git OK
 dig OK
 avahi-resolve OK
 nmap OK
 iputils-ping OK
 file OK
 sshpass OK
 net-tools OK
 Cloning project templates
 Project templates clone OK
 Project templates fetched OK
 Checkout templates repo to dev OK
 Project templates pull ok
 Checking connected devices ...
 Scanning Torizon devices ...
 Configuring debug id_rsa ...
 Debug id_rsa OK
 Torizon IDE extension activated
 Checking host ip sanity ...
 Host ip is OK
 Device 10.22.1.76 set as Docker Host
 Debian bookworm packages list load OK
[01-22 12:20:00.01] ERROR :: pull-container-torizon-debug-arm64 failed with exit code 1
 ERROR :: run-container-torizon-debug-arm64 failed with exit code 1
Tasks logs:
Applying torizonPackages.json ...
Applying to Dockerfile.debug ...
 Dockerfile.debug
Applying to Dockerfile.sdk ...
 Dockerfile.sdk
Applying to Dockerfile ...
 Dockerfile
torizonPackages.json applied
 Dockerfile.debug
 Dockerfile.sdk
 Dockerfile
 Dockerfile.debug
 Dockerfile.sdk
 Dockerfile
 Dockerfile.debug
 Dockerfile.sdk
 Dockerfile
 Dockerfile.debug
 Dockerfile.sdk
 Dockerfile
 Dockerfile.debug
 Dockerfile.sdk
 Dockerfile
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
Unfortunately theres not a lot of information here as to what exactly went wrong. What failed was the pull-container-torizon-debug-arm64 task. This is when the IDE extension pulls the debug container onto the target device. Perhaps there was a network issue, or some other issue with the device. Again hard to say without any more information.
