Error parsing list JSON downloaded from server (TEZI)
I have a local webserver running following the instructions in this page:
My service file looks like:
<!DOCTYPE service-group SYSTEM "avahi-service.dtd">
<service-group>
  <name replace-wildcards="yes">Custom Toradex Easy Installer Feed</name>
  <service>
    <type>_tezi._tcp</type>
    <port>80</port>
    <txt-record>name=Custom Toradex Easy Installer Feed</txt-record>
    <txt-record>path=image_list.json</txt-record>
    <txt-record>enabled=1</txt-record>
    <txt-record>https=0</txt-record>
  </service>
</service-group>
My image_list.json file looks like:
  "config_format": 1,
  "images": [
    "imx8x/image.json"
When I launch the Easy Installer I get the following error:
What am I missing?
Hi @nmohan86,
I tested it here and it worked with your service script and it worked. Looks like you have a parsing error in your JSON file. From the code that you pasted, the first line is a blank line, maybe this is causing the issue. Try with this code:
  "config_format": 1,
  "images": [
    "imx8x/image.json"
Without the new line. Please, check if works or not.
Hiago.
I removed all spaces from the file and I am still getting the same error.
Please find the file attached.
image_list.json (49 Bytes)
I was able to figure it out.
This is the URL that Easy Installer was using to pull image_list.json
http://raspberrypi.local:80image_list.json
which was causing QFileOpen to fail.
I updated the the path in tezi.service to:
 <txt-record>path=/image_list.json</txt-record>
and now everything works.
