I upgraded from LinuxImageV2.6.1 to LinuxImageV2.7 using these commands:
repo init -b LinuxImageV2.7
repo sync
Then I tried to rebuild angstrom-lxde-image:
. export
bitbake -k angstrom-lxde-image
But it fails with ERROR: Task (/home/user/oe-core/build/../layers/meta-snappy/recipes-devtools/go-cross/go-native_1.4.bb:do_compile) failed with exit code '1'
Go 1.4 is end of life. If you are using Go 1.4 to bootstrap a later version, disable cgo with …
which is what meta-snappy does for the go-cross 1.6 (but they also seem to use go-native 1.4 for the snapd recipe).
Note that for the OE pyro version the maintainers of meta-snappy removed the go recipes in favor of using the ones now provided in oe-core so we will get that update going forward.
