[ ERROR :: Errors during the initialization of Torizon IDE Extension.] - VS Code IDE Extension Issue Report (ca5e3c4d69dc2f06dec07c3b6bff5b3b)
OS: linux :: x64 :: WSL 2
Distro: Ubuntu 22.04.2 LTS
Extension activation logs:
 Activating Torizon IDE ...
 Telemetry is enabled
 Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
 Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
 Resolving host IP address ...
 Host IP address OK
 ERROR :: Docker is not installed. Please install Docker: https://docs.docker.com/engine/install/
 ERROR :: Docker compose is not installed. Please install Docker compose https://docs.docker.com/compose/install/
 PowerShell OK
 git OK
 dig OK
 avahi-resolve OK
 nmap OK
 iputils-ping OK
 file OK
 sshpass OK
 net-tools OK
 Cloning project templates
[12-04 08:28:22.08] Project templates clone OK
 Checkout templates repo to v2.3.1 OK
 Checking connected devices ...
 Scanning Torizon devices ...
 Configuring debug id_rsa ...
 Debug id_rsa OK
 HOUSTON WE HAVE A PROBLEM!
 PLEASE READ THE LOGS!
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
Your environment is not configured as described here: Set up the Torizon IDE Extension 2 Environment | Toradex Developer Center
BR,
