[ ERROR :: Errors during the initialization of Torizon IDE Extension.] - VS Code IDE Extension Issue Report (586ae6c529798be699ef74a899b97a13)
OS: linux :: x64 :: WSL 2
Distro: Ubuntu 18.04.6 LTS
Extension activation logs:
 Activating Torizon IDE ...
 User defined host IP address found
 Host IP address OK
 Docker installed OK
 Docker running OK
 Docker compose OK
 ERROR :: PowerShell Core is not installed. Please install: https://docs.microsoft.com/en-us/powershell/scripting/install/installing-powershell-on-linux?view=powershell-7.2
 git OK
 dig OK
 ERROR :: avahi-resolve is not installed.
 Error trying to install git iputils-ping nmap avahi-utils file sshpass net-tools bind9-dnsutils
 ERROR :: GIT not installed, is not possible initialize project template subsystem
 Checking connected devices ...
 Scanning Torizon devices ...
 HOUSTON WE HAVE A PROBLEM!
 PLEASE READ THE LOGS!
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
From the logs there are some missing dependencies the IDE Extension 2 needs. Please install them and see if it works.
Lucas Akira
