[ ERROR :: Errors during the initialization of Torizon IDE Extension.] - VS Code IDE Extension Issue Report (1f47473d75fc8650548b94a62df2a1c5)
OS: linux :: x64 :: WSL 2
Distro: Ubuntu 22.04.2 LTS
Extension activation logs:
 Activating Torizon IDE ...
 Telemetry is enabled
 Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
 Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
 Resolving host IP address ...
 Host IP address OK
 Docker installed OK
 Docker running OK
 Docker compose OK
 ERROR :: PowerShell Core is not installed. Please install: https://docs.microsoft.com/en-us/powershell/scripting/install/installing-powershell-on-linux?view=powershell-7.2
 git OK
 dig OK
 ERROR :: avahi-resolve is not installed.
 Error trying to install git iputils-ping nmap avahi-utils file sshpass net-tools bind9-dnsutils
 ERROR :: GIT not installed, is not possible initialize project template subsystem
 Checking connected devices ...
 Scanning Torizon devices ...
 HOUSTON WE HAVE A PROBLEM!
 PLEASE READ THE LOGS!
Reported by: @
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
Please check the Set up the Torizon IDE Extension 2 Environment | Toradex Developer Center
Is needed to install the dependencies.
BR,
