Hi all,
I’ve started a new project under fsl community BSP (we use poky) with morty branch. Everything was fine until bitbake tries to compile u-boot-toradex-fsl-fw-utils.
ERROR: oe_runmake failed
| HOSTCC scripts/basic/fixdep
| HOSTCC scripts/kconfig/conf.o
| SHIPPED scripts/kconfig/zconf.tab.c
| SHIPPED scripts/kconfig/zconf.lex.c
| SHIPPED scripts/kconfig/zconf.hash.c
| HOSTCC scripts/kconfig/zconf.tab.o
| HOSTLD scripts/kconfig/conf
| scripts/kconfig/conf --silentoldconfig Kconfig
| *** Configuration file ".config" not found!
| *** Please run some configurator (e.g. "make oldconfig" or
| *** "make menuconfig" or "make xconfig").
| make[2]: *** [silentoldconfig] Error 1
| make[1]: *** [silentoldconfig] Error 2
| make: *** No rule to make target `include/config/auto.conf', needed by `include/config/uboot.release'. Stop.
Every layer are set on morty branch. In local.conf file :
MACHINE = 'apalis-imx6'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh"
USER_CLASSES ?= "buildstats image-mklibs"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
STOPTASKS,/tmp,100M,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K \
ABORT,/tmp,10M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
DL_DIR ?= "/home/vincent/fsl-community-bsp/downloads/"
IMAGE_INSTALL_append = " gcc g++ binutils libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev \
autoconf automake ccache chkconfig glib-networking glibmm \
packagegroup-core-buildessential pkgconfig \
boost cmake zlib glib-2.0 packagegroup-fsl-tools-testapps \
cpufrequtils \
nano \
gdb \
openssh-sftp-server \
imx-vpu \
imx-test \
firmware-imx \
qtbase \
qtbase-plugins \
qtbase-tools \
qtdeclarative \
qtdeclarative-plugins \
qtdeclarative-tools \
qtdeclarative-qmlplugins \
qtimageformats-plugins \
qtsystems \
qtsystems-tools \
qtsystems-qmlplugins \
qtgraphicaleffects-qmlplugins \
qtconnectivity-qmlplugins \
qtmultimedia \
qtmultimedia-plugins \
cairo pango fontconfig freetype pulseaudio dbus \
i2c-tools \
gstreamer1.0-plugins-imx \
gst1.0-fsl-plugin \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
psplash \
u-boot-toradex-fsl-fw-utils \
ntfs-3g-ntfsprogs \
DISTRO_FEATURES_remove = "x11 wayland directfb vulka "
IMAGE_INSTALL_remove = "eglinfo-x11"
IMAGE_FEATURES += "dev-pkgs"
KERNEL_IMAGETYPE = "uImage"
ACCEPT_FSL_EULA = "1"
IMAGE_FSTYPES += "ext3"
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer"
PREFERRED_VERSION_linux-toradex = "3.14.28"
UBOOT_CONFIG = "recover spl"
Compilation of u-boot 2016-11 works fine. What are we missing ?
Regards, Vincent
