Hello! Thank you for your question regarding RS-485 on Verdin i.MX8M Plus with the Mallow carrier board.
1. Device Tree Changes
To enable RS-485 mode on UART_1, you need to update the device tree settings for UART4 (since UART_1 on the Verdin i.MX8M Plus corresponds to UART4 in the pin mapping).
Add or modify the following node in your device tree or device tree overlay:
&uart4 {
status = "okay";
linux,rs485-enabled-at-boot-time;
rs485-rts-active-low;
linux,rs485-enabled-at-boot-time;enables RS-485 at boot.rs485-rts-active-low;configures the RTS signal polarity, which is the typical setting for RS-485 transceivers.- Remove or avoid using
rs485-rx-during-tx;unless you specifically need to receive while transmitting, as it can cause echo issues.
For reference:
2. Selecting the Correct Device Tree File
The exact device tree file to modify depends on your BSP version and configuration:
- For Torizon or Toradex BSP Linux, you typically use a device tree overlay (
.dtsfile which compiles to.dtbo). - For Verdin i.MX8M Plus on Mallow, the base device tree is usually:
imx8mp-verdin-mallow.dts - If you are using a custom device tree overlay, you can place the above node in your overlay file.
For detailed information on the board and pin assignments:
General Steps:
- Create a device tree overlay (recommended for Torizon/Core Linux).
- Add the
&uart4node as shown above. - Compile the overlay (
dtc) and deploy it according to your platform’s procedure. - Reboot and confirm RS-485 mode is active.
If you need more guidance on compiling and applying these overlays for your current environment, let me know your Linux variant (Torizon or BSP) and version!
