Hello there!
To enable IrDA communication over the UART interface on your Colibri iMX6ULL, you can follow these steps:
Kernel Configuration for IrDA Support:
- Make sure your Linux kernel is configured with IrDA support. This involves enabling the following options in your kernel configuration:
CONFIG_IRDA: Enable the IrDA subsystem support.CONFIG_IRCOMM: Enable IrDA serial port emulation.CONFIG_IRDA_ULTRA: Enable Ultra (Fast Infrared) support if needed.
- You can configure these options using
make menuconfigor by editing the.configfile directly.
Device Tree Configuration:
- Modify the device tree to configure the UART pins for IrDA mode. This involves setting the correct pin multiplexing for SODIMM 19 and 21 to function as IrDA TX and RX.
- Ensure that the device tree node for the UART interface includes properties for IrDA mode, such as
fsl,irda-modeif applicable.
Driver Modifications:
- Check if the existing UART driver supports IrDA mode. If not, you may need to modify the driver to handle IrDA-specific operations, such as setting the UART to SIR (Serial Infrared) mode.
- This might involve writing or modifying code to switch the UART into IrDA mode, typically by setting specific registers or using ioctl calls.
Testing Tools:
- Use tools like
irattachto attach the IrDA device to a specific UART port. irdadumpcan be used to monitor IrDA traffic and verify communication.- Ensure that the IrDA stack is running by checking the output of
lsmodfor IrDA-related modules.
- Use tools like
By following these steps, you should be able to configure and test IrDA communication on your Colibri iMX6ULL module. If you encounter specific issues, further debugging of the device tree and driver code may be necessary.
Toradex AI Assistant
https://www.toradex.com/computer-on-modules/colibri-arm-family/nxp-imx6ull
