Hello folks,
I am using verdin I.MX8M plus SOM for yocto(dunfell).
I came to know that by default in this BSP for GPU , it uses
MXC_GPU_VIV
For propritory GPU driver , I want to enable open source (etnaviv) GPU driver
For that I modified,
DRM_ETNAVIV
And I have modified local.conf as below.
MACHINE_HAS_VIVANTE_KERNEL_DRIVER_SUPPORT = "0"
MACHINEOVERRIDES .= ":use-mainline-bsp"
DISTRO_FEATURES_append = " opengl wayland"
#MACHINE_USES_VIVANTE_KERNEL_DRIVER_MODULE = "0"
Due to this changes i am getting build error as below.
ERROR: linux-toradex-5.4.161+gitAUTOINC+0f00118249-r0 do_kernel_metadata: Could not locate BSP definition for verdin-imx8mp/standard and no defconfig was provided
+ [ -p /data/verdin-imx8mm/build/tmp/work/verdin_imx8mp-tdx-linux/linux-toradex/5.4.161+gitAUTOINC+0f00118249-r0/temp/fifo.2431783 ]
+ printf %b\0 bbfatal_log Could not locate BSP definition for verdin-imx8mp/standard and no defconfig was provided
+ exit 1
+ bb_exit_handler
+ ret=1
+ echo WARNING: exit code 1 from a shell command.
+ exit 1
ERROR: linux-toradex-5.4.161+gitAUTOINC+0f00118249-r0 do_kernel_metadata: Execution of '/data/verdin-imx8mm/build/tmp/work/verdin_imx8mp-tdx-linux/linux-toradex/5.4.161+gitAUTOINC+0f00118249-r0/temp/run.do_kernel_metadata.2431783' failed with exit code 1
ERROR: Logfile of failure stored in: /data/verdin-imx8mm/build/tmp/work/verdin_imx8mp-tdx-linux/linux-toradex/5.4.161+gitAUTOINC+0f00118249-r0/temp/log.do_kernel_metadata.2431783
ERROR: Task (/data/verdin-imx8mm/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_kernel_metadata) failed with exit code '1'
NOTE: cairo-1.16.0-r0 do_patch: Applying patch 'CVE-2018-19876.patch' (../layers/openembedded-core/meta/recipes-graphics/cairo/cairo/CVE-2018-19876.patch)
NOTE: mesa-2_20.0.2-r0 do_patch: Applying patch '0004-Revert-mesa-Enable-asm-unconditionally-now-that-gen_.patch' (../layers/openembedded-core/meta/recipes-graphics/mesa/files/0004-Revert-mesa-Enable-asm-unconditionally-now-that-gen_.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'introduce-ordered_set_clear-free-with-destructor.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/introduce-ordered_set_clear-free-with-destructor.patch)
NOTE: alsa-lib-1.2.1.2-r0 do_patch: Applying patch '0002-ucm-return-always-at-least-NULL-if-no-list-is-availa.patch' (../layers/openembedded-core/meta/recipes-multimedia/alsa/alsa-lib/0002-ucm-return-always-at-least-NULL-if-no-list-is-availa.patch)
NOTE: cairo-1.16.0-r0 do_patch: Applying patch 'CVE-2019-6461.patch' (../layers/openembedded-core/meta/recipes-graphics/cairo/cairo/CVE-2019-6461.patch)
NOTE: mesa-2_20.0.2-r0 do_patch: Applying patch '0005-vc4-use-intmax_t-for-formatted-output-of-timespec-me.patch' (../layers/openembedded-core/meta/recipes-graphics/mesa/files/0005-vc4-use-intmax_t-for-formatted-output-of-timespec-me.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'network-add-skeleton-of-request-queue.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/network-add-skeleton-of-request-queue.patch)
NOTE: alsa-lib-1.2.1.2-r0 do_patch: Applying patch '0003-namehint-correct-the-args-check.patch' (../layers/openembedded-core/meta/recipes-multimedia/alsa/alsa-lib/0003-namehint-correct-the-args-check.patch)
NOTE: cairo-1.16.0-r0 do_patch: Applying patch 'CVE-2019-6462.patch' (../layers/openembedded-core/meta/recipes-graphics/cairo/cairo/CVE-2019-6462.patch)
NOTE: mesa-2_20.0.2-r0 do_patch: Applying patch '0001-meson-misdetects-64bit-atomics-on-mips-clang.patch' (../layers/openembedded-core/meta/recipes-graphics/mesa/files/0001-meson-misdetects-64bit-atomics-on-mips-clang.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'network-merge-link_drop-and-link_detach_from_manager.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/network-merge-link_drop-and-link_detach_from_manager.patch)
NOTE: alsa-lib-1.2.1.2-r0 do_patch: Applying patch '0004-namehint-improve-the-previous-patch-check-the-return.patch' (../layers/openembedded-core/meta/recipes-multimedia/alsa/alsa-lib/0004-namehint-improve-the-previous-patch-check-the-return.patch)
NOTE: cairo-1.16.0-r0 do_patch: Applying patch 'CVE-2020-35492.patch' (../layers/openembedded-core/meta/recipes-graphics/cairo/cairo/CVE-2020-35492.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'network-also-drop-requests-when-link-enters-linger-state.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/network-also-drop-requests-when-link-enters-linger-state.patch)
NOTE: alsa-lib-1.2.1.2-r0 do_patch: Applying patch '0005-ucm-Do-not-fail-to-parse-configs-on-cards-with-an-em.patch' (../layers/openembedded-core/meta/recipes-multimedia/alsa/alsa-lib/0005-ucm-Do-not-fail-to-parse-configs-on-cards-with-an-em.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'network-fix-Link-reference-counter-issue.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/network-fix-Link-reference-counter-issue.patch)
NOTE: alsa-lib-1.2.1.2-r0 do_patch: Applying patch '0001-Fix-alsa-sound-.h-for-external-programs.patch' (../layers/openembedded-core/meta/recipes-multimedia/alsa/alsa-lib/0001-Fix-alsa-sound-.h-for-external-programs.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'rm-rf-refactor-rm-rf-children-split-out-body-of-directory.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/rm-rf-refactor-rm-rf-children-split-out-body-of-directory.patch)
NOTE: alsa-lib-1.2.1.2-r0 do_patch: Applying patch '0001-uapi-Move-typedefs-from-uapi-to-sound.patch' (../layers/openembedded-core/meta/recipes-multimedia/alsa/alsa-lib/0001-uapi-Move-typedefs-from-uapi-to-sound.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'rm-rf-optionally-fsync-after-removing-directory-tree.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/rm-rf-optionally-fsync-after-removing-directory-tree.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'CVE-2021-3997-1.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/CVE-2021-3997-1.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'CVE-2021-3997-2.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/CVE-2021-3997-2.patch)
NOTE: systemd-1_244.5-r0 do_patch: Applying patch 'CVE-2021-3997-3.patch' (../layers/openembedded-core/meta/recipes-core/systemd/systemd/CVE-2021-3997-3.patch)
NOTE: Tasks Summary: Attempted 2252 tasks of which 2237 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 3 seconds
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
My motive is to try open source and close source GPU drivers for wpewebkit performance analysis.
Can anyone guide me here ?
Thanks.
