Hi @Sivasubramaniyan ,
In case of bootloader not working one need to reflash module using Toradex easy installer.
Also let us know if while secure booting you have closed the device or it is still open. In case of device close and non working uboot, it’s more likely will not work with reflashing also as module will expect signed firmware to boot.
Regarding steps for using HAB I am afraid as of now we do not have step by step guide, NXP guide is what you need to refer. Additionally please check below post for solution and info regarding HAB on iMX6ULL
Ritesh Kumar
