Hi Team,
I was able compile multimedia image using eiQ version zeus-5.4.70-2.3.1 with Toradex BSP version 5.2.0. Now, We want to integrate latest version of Tensorflow Lite that supports VX Delegate and DeepViewRT and that comes from eIQ Version hardknott-5.10.35-2.0.0. DeepViewRT and Torch failed during compilation.
Please find the error log below,
Pytorch:
ERROR: deepview-rt-2.4.25-aarch64-r0 do_unpack: A valid package EULA with md5sum in ['01ba08a2b77c3a0a9d0ab5d4d83fed64', '3880bb9c943b135a30fad5e8aabd3ee9', 'a31dce3023402a821cfcdc1bb8dbdbc0', '8cf95184c220e247b9917e7244124c5a', '102094e9e695888c6a9f9fda9004165d', 'd4f548f93b5fe0ee2bc86758c344412d', 'be67a88e9e6c841043b005ad7bcf8309', '88595f92466edd79be7f4f9547ffa0ef', '6b552f505eedab4a11ab538cf3db743a', '08fd295cce89b0a9c74b9b83ed74f671', '6bd2df2910a2234bf6f419b7d2f531a3', '75abe2fa1d16ca79f87cde926f05f72d', 'ab61cab9599935bfe9f700405ef00f28', '5ab1a30d0cd181e3408077727ea5a2db', '6dfb32a488e5fd6bae52fbf6c7ebb086', '80c0478f4339af024519b3723023fe28', 'fb0303e4ee8b0e71c094171e2272bd44', '72c0f70181bb6e83eee6aab8de12a9f3', '6c12031a11b81db21cdfe0be88cac4b3', 'fd4b227530cd88a82af6a5982cfb724d', '228c72f2a91452b8a03c4cab30f30ef9', '1b4db4b25c3a1e422c0c0ed64feb65d2', '983e4c77621568488dd902b27e0c2143', 'e9e880185bda059c90c541d40ceca922', 'cf3f9b8d09bc3926b1004ea71f7a248a'] was not found in LIC_FILES_CHKSUM 'file://COPYING;md5=f35df765ff17e69043ea21f350e3229c file:///home/nullbyte/yocto-ml-build/bsp-toradex/build/../layers/meta-freescale/EULA;md5=228c72f2a91452b8a03c4cab30f30ef9'.
ERROR: Logfile of failure stored in: /home/nullbyte/yocto-ml-build/bsp-toradex/build/tmp/work/aarch64-tdx-linux/deepview-rt/2.4.25-aarch64-r0/temp/log.do_unpack.202085
ERROR: Task (/home/nullbyte/yocto-ml-build/bsp-toradex/layers/meta-ml/recipes-libraries/deepview-rt/deepview-rt_2.4.25-aarch64.bb:do_unpack) failed with exit code '1'
DeepViewRT:
ERROR: pytorch-1.7.1-r0 do_package_qa: QA Issue: /usr/lib/python3.8/site-packages/torch/lib/libtorch_python.so contained in package pytorch requires libc.so.6(GLIBC_2.33)(64bit), but no providers found in RDEPENDS_pytorch? [file-rdeps]
ERROR: pytorch-1.7.1-r0 do_package_qa: QA Issue: /usr/lib/python3.8/site-packages/torch/lib/libtorch_python.so contained in package pytorch requires libc.so.6(GLIBC_2.32)(64bit), but no providers found in RDEPENDS_pytorch? [file-rdeps]
Jegathesan S
