EGL Native Window creation on imx6 ,
Dear
I want to setup a EGL Window without X or Wayland. Do you have any example code?
Best regards
Martin ,
Hi Martin
You have to build your own image with openembedded.
Please have a look at this post.
Max
Thanks thats may help to build the image.
Do you have an example code to use egl without x or wayland.
Best
Unfortunately not.
I guess all requests for this were from people using it with Qt5 and then using eglfs as the backend.
I doubt expect the qtbase sources to be to big a system to server as example code.
Max
