Hi!
I followed the guide for easyinstallerbuilder.
The syntax described in the knowledge-base is outdated and the script seems buggy.
When calling like this:
docker run -it --rm -v $(pwd)/fs:/builder/fs -v $(pwd)/output:/builder/output torizon/ostree-easy-installer-builder:latest easyinstallerbuilder -V -m apalis-imx8 -i torizon-core-docker -r http://feeds.toradex.com/ostree/torizoncore-master/nightly -b torizon/torizon-core-docker -s /builder/fs -o /builder/output
the command results in a traceback:
Unexpected error
File "/builder/easyinstallerbuilder", line 562, in <module>
generateTeziImage(args.module, args.image, args.repo, args.branch, args.srcdir, args.outputdir, args.version)
File "/builder/easyinstallerbuilder", line 328, in generateTeziImage
imagename, imagejson = getTeziImagePath(module, image, version)
File "/builder/easyinstallerbuilder", line 138, in getTeziImagePath
_, imageversion = imagenamenoprefix.split("_")
ValueError: too many values to unpack (expected 2)
This can be fixed in easyinstallerbuilder:138 by changing the line to:
imageversion = imagenamenoprefix.split(“_”)[-1]
Still the script fails with:
Pulling remote http://feeds.toradex.com/ostree/torizoncore-master/nightly/apalis-imx8 torizon/torizon-core-docker
Unexpected error
File "/builder/easyinstallerbuilder", line 565, in <module>
File "/builder/easyinstallerbuilder", line 387, in generateTeziImage
repo, srcdir, remote, branch, branchname, finalname, ostreeutils.changed)
File "/builder/ostreeutils.py", line 199, in mergeChanges
pullRemote(repo, remote, remoteBranch, changed)
File "/builder/ostreeutils.py", line 65, in pullRemote
if not repo.pull_with_options("origin", options, progress=asyncprogress):
gi.repository.GLib.GError: g-io-error-quark: No such branch 'torizon/torizon-core-docker' in repository summary (0)
Please update the knowledge-base article how to use this command.
Thank you,
Peter
