Easy Installer of only dtb files
Yes, to update only the device tree without affecting the operating system using EasyInstaller, you should remove the specified section from the image.json file. This section is responsible for updating the OS, and by deleting it, you will ensure that only the device tree is updated.
Toradex Easy Installer Configuration Files | Toradex Developer Center.
