Easy Installer Error downloading or writing image
I’m trying to build an image for a Colibri iMX7D 1GB following this guide.
I’m working from Windows10 on a virtual machine running Ubuntu 18.04 (Virtualbox).
I then transfer the oe-core/build/deploy/images/colibri-imx7-emmc folder on an USB drive and use it to flash the image on the board via Toradex Easy Installer (v 2.0b7).
I’m experiencing 3 issues:
  • sometimes the image on the drive is not listed at all in the available images in Toradex Easy Installer
  • sometimes an image is found but is listed as not compatible with the module
  • even when the image is listed and compatible, I try to install it but the following error message is shown:
xz: (stdin): File format not recognized
tar: This does not look like a tar archive
tar: Exiting with failure status due to previous errors
Can you please tell me what I’m doing wrong?
Thank you
Thank you Alex, it worked.
Marco
If build completed successfully you should get a tar file which contains Toradex Easy Installer compatible image. For example: Colibri-iMX7-eMMC_Reference-Minimal-Image-Tezi_5.2.0+build.7.tar Please check for details here.
Then you need to untar that file to USB drive. And use it to flash Colibri module.
