Hi everyone ,
i have 3rd party dynamic library file(.so) , its compile successfully but run time getting failed . its shows compiler issue. same dynamic lib is running in Ubuntu.
Hi everyone ,
Hi @Anil ,
Kindly share complete environment and setup details in order to understand query well like steps you have followed, how are you compiling and library which you are working with.
Also are you referring to same .so file which is running well in ubuntu on your development pc if so then you need to cross compile same library for arm arch and then use it.
Kindly share complete software and hardware details to further support you with your query.
Ritesh Kumar
