I am trying to apply sensoray 1012 for IMX8.
I followed this guilde here to build an image:
https://developer.toradex.com/knowledge-base/board-support-package/openembedded-core
and after for kernel driver activation:
bitbake virtual/kernel -c menuconfig
and i activate the below settings for Sensoray reccomends below with no problem:
http://www.sensoray.com/wiki/index.php?title=1012_TORADEX
Use arrows to scroll down to “Device Drivers —>”: Press Enter ()
Use arrows to scroll down to:
“Multimedia support”: Press Enter
Use arrows to scroll down to: “Analog
TV support”: Press Space Bar. Item
selected will have an asterisk *.
Use arrows to scroll down to: “Media
USB Adapters”: Press Enter
Use arrows to scroll down to: “USB
Sensoray 2255 Video capture device”:
Press Space bar to select.
Press right arrow once until
is selected. Press Enter.
PCI Adapters”: Press Space Bar to
select then press Enter.
Use down arrow to scroll down to:
“TW686x cards (NEW)”.: Press Space
Bar to select and press Enter
"Philips SAA7134 support (NEW): Press
Space Bar to select and press
Enter. This installed other libraries
that #may be useful in the future
without having to recompile the
entire kernel.
is selected. Press Enter. Multimedia
support menu will appear.
is selected. Press Enter. This brings
you back to the device drivers root
menu.
you back to the main kernel root
menu.
is selected. Press Enter. A pop-up
asking if you want to save your new
configuration appears. should
be #selected. Press enter to save the
configuration.
After these setting bitbake again:
bitbake tdx-reference-multimedia-image
bitbake ends with this warning maybe relevent:
WARNING: /home/stg/oe-core/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_compile is tainted from a forced run
But drivers doesnt get loaded.
Here is the start-up output relevent with PCI and TW686x driver:
[ 3.612508] pci 0000:00:00.0: BAR 0: assigned [mem 0x60000000-0x60ffffff]
[ 3.619329] pci 0000:00:00.0: BAR 6: assigned [mem 0x61000000-0x61ffffff pref]
[ 3.626598] pci 0000:00:00.0: BAR 14: assigned [mem 0x62000000-0x620fffff]
[ 3.633494] pci 0000:01:00.0: BAR 0: assigned [mem 0x62000000-0x62000fff pref]
[ 3.640756] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 3.646021] pci 0000:00:00.0: bridge window [mem 0x62000000-0x620fffff]
[ 3.653276] pcieport 0000:00:00.0: PME: Signaling with IRQ 568
[ 3.659449] tw6869: PCI 0000:01:00.0, IRQ 568, MMIO 0x62000000 (memcpy mode)
[ 3.666543] tw686x 0000:01:00.0: enabling device (0000 → 0002)
[ 3.673621] tw686x 0000:01:00.0: dma0: unable to allocate P-buffer
[ 3.679837] tw686x 0000:01:00.0: can’t register video
[ 3.684938] tw686x: probe of 0000:01:00.0 failed with error -12
root@apalis-imx8:~# modinfo tw686x
modinfo: ERROR: Module tw686x not found.
i see some imx6q. Might this coused by a wrong setting? I am using Apalis IMX8QM
[ 3.075401] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff pref]
[ 3.090684] pci 0000:01:00.0: enabling Extended Tags
[ 3.095910] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 3.107150] ALSA device list:
[ 3.110135] #0: imx-spdif
[ 3.112940] #1: apalis-imx8qm-sgtl5000
[ 3.118532] pci 0000:00:00.0: BAR 0: assigned [mem 0x60000000-0x60ffffff]
[ 3.125346] pci 0000:00:00.0: BAR 6: assigned [mem 0x61000000-0x61ffffff pref]
[ 3.132586] pci 0000:00:00.0: BAR 14: assigned [mem 0x62000000-0x620fffff]
[ 3.139498] pci 0000:01:00.0: BAR 0: assigned [mem 0x62000000-0x62000fff pref]
[ 3.146749] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 3.151990] pci 0000:00:00.0: bridge window [mem 0x62000000-0x620fffff]
[ 3.159346] pcieport 0000:00:00.0: PME: Signaling with IRQ 568
[ 3.165705] tw6869: PCI 0000:01:00.0, IRQ 568, MMIO 0x62000000 (memcpy mode)
[ 3.172826] tw686x 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.180062] tw686x 0000:01:00.0: dma0: unable to allocate P-buffer
[ 3.186270] tw686x 0000:01:00.0: can't register video
[ 3.191390] tw686x: probe of 0000:01:00.0 failed with error -12
[ 3.192014] imx6q-pcie 5f010000.pcie: PCIe PLL locked after 0 us.
[ 3.203503] imx6q-pcie 5f010000.pcie: host bridge /bus@5f000000/pcie@0x5f010000 ranges:
[ 3.211556] imx6q-pcie 5f010000.pcie: IO 0x7ff80000..0x7ff8ffff -> 0x00000000
[ 3.218983] imx6q-pcie 5f010000.pcie: MEM 0x70000000..0x7fefffff -> 0x70000000
[ 3.332030] usb 4-1: new high-speed USB device number 2 using ci_hdrc
[ 3.493192] hub 4-1:1.0: USB hub found
[ 3.497178] hub 4-1:1.0: 3 ports detected
[ 4.227038] imx6q-pcie 5f010000.pcie: Phy link never came up
[ 4.232789] imx6q-pcie 5f010000.pcie: failed to initialize host
[ 4.238794] imx6q-pcie 5f010000.pcie: unable to add pcie port.
Hello @Engineering_AV ,
Greetings and Welcome to Toradex Community!
One thing you could try is to bitbake -c cleanall
and resume the build. Please kindly refer to the following pages that discusses this issue in detail:
https://community.nxp.com/t5/i-MX-Processors/fsl-image-validation-imx-bb-do-build-is-tainted-from-a-forced/td-p/888442
https://www.yoctoproject.org/pipermail/yocto/2015-January/023274.html
Hope this helps!
Janani
Hello @saijanani.tx and thank you for your reply.
One thing you could try is to bitbake -c cleanall and resume the build.
Solved some problems.
Now there is no tw686x memcpy error at start up output. And i can do
when i do modinfo
filename: /lib/modules/5.4.91-5.2.0-devel+git.c59b3c2da1e9/kernel/drivers/media/pci/tw686x/tw686x.ko
license: GPL v2
author: Krzysztof Ha?asa <khalasa@piap.pl>
author: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
description: Driver for video frame grabber cards based on Intersil/Techwell TW686[4589]
alias: pci:v00001797d00006869sv*sd*bc*sc*i*
alias: pci:v00001797d00006868sv*sd*bc*sc*i*
alias: pci:v00001797d00006865sv*sd*bc*sc*i*
alias: pci:v00001797d00006864sv*sd*bc*sc*i*
depends: videobuf2-dma-sg
intree: Y
vermagic: 5.4.91-5.2.0-devel+git.c59b3c2da1e9 SMP preempt mod_unload modversions aarch64
parm: dma_interval:Minimum time span for DMA interrupting host (int)
parm: dma_mode:DMA operation mode (memcpy/contig/sg, default=memcpy)
when i lscpci -v
root@apalis-imx8:~# lspci -v
00:00.0 PCI bridge: Freescale Semiconductor Inc Device 0000 (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 568
Memory at 60000000 (32-bit, non-prefetchable) [size=16M]
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: 62000000-620fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Expansion ROM at 61000000 [virtual] [disabled] [size=16M]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/16 Maskable- 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Secondary PCI Express
Capabilities: [168] L1 PM Substates
Kernel driver in use: pcieport
01:00.0 Unclassified device [0004]: Intersil Techwell Device 6869 (rev 01)
Flags: fast devsel, IRQ 568
Memory at 62000000 (32-bit, prefetchable) [size=4K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Legacy Endpoint, MSI 00
Capabilities: [140] Virtual Channel
Kernel modules: tw686x
But still i cant reach sensoray 1012(i should see 8 more video input here).
root@apalis-imx8:~# ls /dev/video*
/dev/video0 /dev/video1 /dev/video12 /dev/video13
root@apalis-imx8:~# GST_DEBUG=2 gst-device-monitor-1.0 video
Probing devices...
0:00:00.052641948 1572 0xaaaaf7281460 WARN default gstdevicemonitor.c:466:gst_device_monitor_start:<devicemonitor0> No providers match ths
Failed to start device monitor!
No, various SoCs just share certain IP like in this case where the PCIe IP of the i.MX 6 and i.MX 8 is similar and therefore using the same driver.
Greatings,
Thanks for your answer @saijanani.tx
bitbake -c cleanall
followed by bitbake solved some of the problems. Now there is no kernel boot error about tw868x. And now i can see an output with modinfo tw686x
license: GPL v2
intree: Y
but still sensoray 1012 device is unclassified:
Pci has the right driver(tw686x) but still it doesnt work. There should be 8 mode video device.
Probing devices...
0:00:00.052878578 1933 0xaaaae7b5c460 WARN default gstdevicemonitor.c:466:gst_device_monitor_start:<devis
is there any idea how can i activate this device.
Best regards, Ugur
Solved:
The problem was about pci. At sturtup press space for u-boot and
# setenv defargs 'pci=nomsi coherent_pool=128M'
# saveenv
# reset
Perfect. Thanks for your Input.
