Download and build the Toradex Image
I have version of Apalis-iMX6_LXDE-Image 2.7b4 20171004 what version of the bsp. How can I download and build the Toradex Image.
I have flashed a new version of the Apalis-iMX6 with the image Apalis-iMX6_LXDE-Image 2.7b4 20171004.
Does toradex prove a way to build the oe-core for this version using the oe-core build instructions? Is this a branch that I can repo?
hi @josburn@multisensorscientific.com
Welcome to the Toradex Community!
You can follow the Instructions on this site to do the Oe-Core Build of Toradex Images.
Hi
Which repo branch did you checkout?
Have you done any changes to the files before doing the compilation?
Additionally could you check the Troubleshoot Instructions for failing Builds?
Thanks and best regards,
Attempted to build with the tag and the given result followed.
josburn@super:~/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build$ bitbake angstrom-lxde-image
Loading cache: 100% |######################################################################################################| Time: 0:00:01
Loaded 3419 entries from dependency cache.
WARNING: No recipes available for:
  /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/meta-jetson-tk1/recipes-graphics/mesa/mesa_11.1.1.bbappend
  /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/meta-angstrom/recipes-tweaks/ecj/ecj-initial-native.bbappend
Build Configuration:
BB_VERSION        = "1.32.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-18.04"
TARGET_SYS        = "arm-angstrom-linux-gnueabi"
MACHINE           = "colibri-t20"
DISTRO            = "angstrom"
DISTRO_VERSION    = "v2016.12"
TUNE_FEATURES     = "arm armv7a vfp thumb            callconvention-hard"
TARGET_FPU        = "hard"
meta-angstrom     = "HEAD:9625910bb4bb48b3f4d87a1e9ff3576d40bd656a"
meta-toradex-nxp  = "HEAD:45c33b79a734d016dddb997c1895b53202286f23"
meta-freescale    = "HEAD:05681fdf8298bb441c15135eae424c7601b07e98"
meta-freescale-3rdparty = "HEAD:1879485e63ce369292c89b5902ff6df13509090b"
meta-toradex-tegra = "HEAD:942eeb98172f74e9fbf8f6053cf241e3fb98110b"
meta-jetson-tk1   = "HEAD:e8b87fe8da7c6fcffa37ab245f50082953cc1ee1"
meta-toradex-bsp-common = "HEAD:429d294f9b271433d4d0130530677dc417e6ec6e"
meta-snappy       = "HEAD:f6df6a63756d9976bcccb5fefdbc64e5cc794c99"
meta-linaro-toolchain = "HEAD:49b0f32d7e955f250b0022d1b2f403f45a2c2d9c"
meta-oe
meta-efl
meta-gpe
meta-gnome
meta-xfce
meta-initramfs
meta-systemd
meta-networking
meta-multimedia
meta-python       = "HEAD:b40116cf457b88a2db14b86fda9627fb34d56ae6"
meta-lxde         = "HEAD:1bd36a4d0f7e1e9fdea9c4c991188bc1dc9da421"
meta-browser      = "HEAD:1569eeb9cc1b87632abbf35fbb05f4ac4eeb3987"
meta-qt4          = "HEAD:f389368dc86e745df14cab9eeb9a94bc02bd273e"
meta-qt5          = "HEAD:2c9f0e4eb0e9097f6f872ec1e1d81768a8ab5f1b"
meta-freescale-distro = "HEAD:cd5c7a2539f40004f74126e9fdf08254fd9a6390"
meta-toradex-demos = "HEAD:d4107c7913695e59ec41401ae9036946e348f5fe"
meta              = "HEAD:b835e9bf9da6ebc8fd5728b4587470e9a57d5966"
Initialising tasks: 100% |#################################################################################################| Time: 0:00:19
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: gnu-config-native-20150728+gitAUTOINC+b576fa87c1-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
fatal: the '--set-upstream' option is no longer supported. Please use '--track' or '--set-upstream-to' instead.
ERROR: gnu-config-native-20150728+gitAUTOINC+b576fa87c1-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/gnu-config-native/20150728+gitAUTOINC+b576fa87c1-r0/temp/log.do_unpack.16744
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-devtools/gnu-config/gnu-config_git.bb:do_unpack) failed with exit code '1'
ERROR: opkg-utils-0.3.2+gitAUTOINC+3ffece9bf1-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: opkg-utils-0.3.2+gitAUTOINC+3ffece9bf1-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/opkg-utils/0.3.2+gitAUTOINC+3ffece9bf1-r0/temp/log.do_unpack.16752
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb:do_unpack) failed with exit code '1'
ERROR: pkgconfig-native-0.29.1+gitAUTOINC+87152c05be-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: pkgconfig-native-0.29.1+gitAUTOINC+87152c05be-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/pkgconfig-native/0.29.1+gitAUTOINC+87152c05be-r0/temp/log.do_unpack.16746
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_unpack) failed with exit code '1'
ERROR: dtc-native-1.4.1+gitAUTOINC+302fca9f4c-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: dtc-native-1.4.1+gitAUTOINC+302fca9f4c-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/dtc-native/1.4.1+gitAUTOINC+302fca9f4c-r0/temp/log.do_unpack.16753
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-kernel/dtc/dtc_git.bb:do_unpack) failed with exit code '1'
ERROR: lz4-131+gitAUTOINC+d86dc91677-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: lz4-131+gitAUTOINC+d86dc91677-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/lz4/131+gitAUTOINC+d86dc91677-r0/temp/log.do_unpack.16759
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-support/lz4/lz4.bb:do_unpack) failed with exit code '1'
ERROR: file-native-5.28-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: file-native-5.28-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/file-native/5.28-r0/temp/log.do_unpack.16751
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-devtools/file/file_5.28.bb:do_unpack) failed with exit code '1'
ERROR: prelink-native-1.0+gitAUTOINC+ef20628dd7-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream cross_prelink origin/cross_prelink failed with exit code 128, output:
ERROR: prelink-native-1.0+gitAUTOINC+ef20628dd7-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/prelink-native/1.0+gitAUTOINC+ef20628dd7-r0/temp/log.do_unpack.16756
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-devtools/prelink/prelink_git.bb:do_unpack) failed with exit code '1'
ERROR: ncurses-native-6.0+20160625-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: ncurses-native-6.0+20160625-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/ncurses-native/6.0+20160625-r0/temp/log.do_unpack.16750
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-core/ncurses/ncurses_6.0+20160625.bb:do_unpack) failed with exit code '1'
ERROR: kmod-23+gitAUTOINC+65a885df5f-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: kmod-23+gitAUTOINC+65a885df5f-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/kmod/23+gitAUTOINC+65a885df5f-r0/temp/log.do_unpack.16758
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-kernel/kmod/kmod_git.bb:do_unpack) failed with exit code '1'
ERROR: ncurses-6.0+20160625-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: ncurses-6.0+20160625-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/ncurses/6.0+20160625-r0/temp/log.do_unpack.16754
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-core/ncurses/ncurses_6.0+20160625.bb:do_unpack) failed with exit code '1'
ERROR: systemd-1_230+gitAUTOINC+3a74d4fc90-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/perl-native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream master origin/master failed with exit code 128, output:
ERROR: systemd-1_230+gitAUTOINC+3a74d4fc90-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/systemd/1_230+gitAUTOINC+3a74d4fc90-r0/temp/log.do_unpack.16761
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-core/systemd/systemd_230.bb:do_unpack) failed with exit code '1'
ERROR: glibc-initial-2.24-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi.gcc-cross-initial-arm:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream release/2.24/master origin/release/2.24/master failed with exit code 128, output:
ERROR: glibc-initial-2.24-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7ahf-vfp-angstrom-linux-gnueabi/glibc-initial/2.24-r0/temp/log.do_unpack.16748
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc-initial_2.24.bb:do_unpack) failed with exit code '1'
ERROR: binutils-cross-arm-linaro-2.27-r2016.10 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/texinfo-dummy-native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream linaro_binutils-2_27-branch origin/linaro_binutils-2_27-branch failed with exit code 128, output:
ERROR: binutils-cross-arm-linaro-2.27-r2016.10 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/binutils-cross-arm/linaro-2.27-r2016.10/temp/log.do_unpack.16747
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/meta-linaro/meta-linaro-toolchain/recipes-devtools/binutils/binutils-cross_linaro-2.27.bb:do_unpack) failed with exit code '1'
ERROR: glibc-2.24-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi.gcc-cross-initial-arm:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream release/2.24/master origin/release/2.24/master failed with exit code 128, output:
ERROR: glibc-2.24-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/armv7ahf-vfp-angstrom-linux-gnueabi/glibc/2.24-r0/temp/log.do_unpack.16749
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.24.bb:do_unpack) failed with exit code '1'
ERROR: binutils-native-linaro-2.27-r2016.10 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts/native-intercept:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/texinfo-dummy-native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/x86_64-linux:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream linaro_binutils-2_27-branch origin/linaro_binutils-2_27-branch failed with exit code 128, output:
ERROR: binutils-native-linaro-2.27-r2016.10 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work/x86_64-linux/binutils-native/linaro-2.27-r2016.10/temp/log.do_unpack.16755
ERROR: Task (virtual:native:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/meta-linaro/meta-linaro-toolchain/recipes-devtools/binutils/binutils_linaro-2.27.bb:do_unpack) failed with exit code '1'
ERROR: gcc-source-linaro-6.2-linaro-6.2-r2016.11 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export PATH="/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin/arm-angstrom-linux-gnueabi:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/colibri-t20/usr/bin/crossscripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/usr/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/sbin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/sysroots/x86_64-linux/bin:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/scripts:/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin"; export HOME="/home/josburn"; git -c core.fsyncobjectfiles=0 branch --set-upstream linaro-local/releases/linaro-6.2-2016.11 origin/linaro-local/releases/linaro-6.2-2016.11 failed with exit code 128, output:
ERROR: gcc-source-linaro-6.2-linaro-6.2-r2016.11 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/tmp-glibc/work-shared/gcc-linaro-6.2-r2016.11/temp/log.do_unpack.16745
ERROR: Task (/home/josburn/oe-core-Apalis-iMX6_LXDE-Image_2.7b4-20171005/build/../layers/meta-linaro/meta-linaro-toolchain/recipes-devtools/gcc/gcc-source_linaro-6.2.bb:do_unpack) failed with exit code '1'
NOTE: Tasks Summary: Attempted 465 tasks of which 449 didn't need to be rerun and 16 failed.
NOTE: Writing buildhistory
Summary: 16 tasks failed:
Summary: There was 1 WARNING message shown.
Summary: There were 32 ERROR messages shown, returning a non-zero exit code.
Hi
The following message is caused by newer git versions:
Either:
  • Stop using a much newer distro as the build host (e.g. one which has git older than 2.14.1.473.g3ec7d702a).
  • Prefer latest and greatest of the 2.7 BSP over an unsupport beta version (2.7.4).
  • Cherry-pick commit 991b533f1d61042a7b3edd1fbf3dea0bf9991606 into the bitbake repository.
For the third option you would
cd oe-core/layers/openembedded-core/bitbake
git fetch repo
git cherry-pick 991b533f1d61042a7b3edd1fbf3dea0bf9991606
Max
