Hello!
I need to downgrade image on my Colibri VF61 modules from v1.5 to v1.4.
I can do this using recovery mode for bootloader downgrade and using eboot command prompt mode for image downgrade. In this case all is OK.
But for production purpose I use programming script:
echo Copying bootloader and image
..\utils\cecopy .\Images_1.5\update.exe dev:\FlashDisk
..\utils\cecopy .\Images_1.4\eboot.img dev:\FlashDisk
..\utils\cecopy .\Images_1.4\nk6.bin dev:\FlashDisk
cd ..\Misc
call ClearRegistry.bat
cd ..\Images_VF61
echo Flashing bootloader
..\Utils\rapistart.exe \FlashDisk\update.exe /u bootloader,raw,\FlashDisk\eboot.img
ping -n 5 127.0.0.1 >NUL:
echo Flashing Image
..\Utils\rapistart.exe \FlashDisk\update.exe /u os,bin,\FlashDisk\nk6.bin
cd ..\Misc
..\utils\cecopy configblock.cfg dev:\FlashDisk\configblock.cfg
..\utils\rapistart.exe \Flashdisk\update.exe /u configblock,raw,\Flashdisk\configblock.cfg
..\utils\rapimove -d \FlashDisk\configblock.cfg
cd ..\Images_VF61
cd ..\Misc
call ResetColibri.bat
cd ..\Images_VF61
timeout /t 1
echo "Waiting until ActiveSync will be started..."
..\Misc\WaitForDeviceConnection.exe
echo "Deleting bootloader and image from Flashdisk"
..\utils\rapimove -d \FlashDisk\eboot.img
..\utils\rapimove -d \FlashDisk\nk6.bin
In this script I use a new Update Tool (updatetool.exe from colibri-vybrid_winceimage_1.5.zip). Script works without any errors, but when I insert Colibri to evaluation board, I see message in serial console
Toradex Windows CE 6.0 1.5 for Vybrid Built Dec 18 2017
Bootloader version in this case is 1.4, as expected.
Why my script does not downgrade image?
The file is on the folder, and copying to dev:FlashDisk is OK.
I tryed this script for upgrade from 1.4beta2 to 1.4 and got the same result (image version remain the same). But if I use “update.exe” from colibri-vybrid_winceimage_1.4.zip, upgrade works fine.
So I think the problem is in “update.exe” from colibri-vybrid_winceimage_1.5.zip.
Do you have any ideas?
Instead of running the script, execute each step manually
Activate additional verbosity for each command, if possible
After each command, verify that the command was executed correctly
Watch the output in the console and the terminal program to spot any possible errors
Let us know which step failes, and what was the error message. It might be useful to post the full output of the console and the terminal program here for reference
works fine only if there is inserted SD card with image file nk6.bin.
Why ‘update.exe’ uses file nk6.bin on SD card, although I wrote ‘,\FlashDisk\nk6.bin’ in command?
works fine.
But when I use our own device (industrial PocketPC), this command doesn’t run. I see a message “Update failed” in CeRHost window.
Do you know any hardware dependencies of UpdateTool?
We didn’t have this problem with UpdateTool from image archive v1.4.
Dear @Kpa87
I was able to reproduce the issue. It happens also without rapistart.exe (just calling the update.exe from the WinCE command shell).
You can find attached a preliminary nightly build of the update tool, with this issue fixed.
