I’ve developed an application on M4 core of Colibri VF61 which uses SPI1 peripheral (SPI1_SCK, SPI1_SIN, SPI1_SOUT and SPI1_PCS0 pins).
The application runs fine when I load it to M4 core through Keil ULINK Pro debugger,
When I load and execute it from WinCE 6 (using rpmsg library), after a while SPI1_PCS0 is not asserted anymore.
Does WinCE 6 for VF61 somehow use SPI1 pins?
Does WinCE 6 for VF61 use SPI1_PCS0 pin for some purpose?
After a deeper investigation, I found that after a while, M4 core jumps into Hardware Fault Handler.
I suspect some conflict between how A5 and M4 want to configure registers.
Is there a way to debug this kind of problems?
Hello @luka.tx
I investigated, and I’m sure M4 jumps into Hard Fault when the application is loaded from A5.
The same application works perfectly when it’s loaded into M4 using Keil debugger.
I suspect some issues while setting clocks or DMA; but I used DMA1 only, based on your suggestion.
Do you have any experience in this kind of issues?
Thank you.
Up to now on M4 side I use OCRAM only (for code and data) so I think I should not have problems.
Could you confirm that WinCE 6 on A5 doesn’t use OCRAM?
I’m going to open a new topic to get help on how to share DDR memory between M4 and A5 (I need it in the future).
