I am in the process of designing a carrier board based on the Colibri standard.
Do you provide reference schematics or similar documents which can help me in this process?
Toradex helps the customer which are working on a carrier board design in various ways.
The developer page dedicated to this topic can be found here:
On this page the Toradex customers can find all the following instrument which will make the carrier board design easier:
Pinout Designer: this is a powerful tool which can be used to define the pin muxing of the Colibri and Apalis modules. By using this tool it will be possible to explore and select the standard and optional interfaces available on the Toradex modules.
Apalis and Colibri Carrier board design guides and Layout design guides: these guides are full of technical information and details regarding schematic and layout design. Using them will increase the probability to get your design right first time.
Carrier and add-on board Altium Designs: Toradex provides the complete Altium Design of the carrier board and the add-on boards. The customers can open the schematic files to reuse some parts, access the component libraries open the layout file and adjust it according to their requirements.
