I would like to know if it is possible to use an application already compiled from qt 4.8.2 in a verdin mini?
If not, could someone give me support to update an application to the current version of qt? What would be the price?
Thank you very much for your attention and kindness.
Now the Linux BSP on Verdin iMX8M Mini has Wayland as a graphic backend framework. We recommend Qt5 which can make the most of the GPU. The default Qt version on our reference image is Qt5.14 but you can easily upgrade to Qt5.15 by replacing meta-qt5 recipes.
Ohhhh, thanks for your answer.
Hugs
