I have compiled and run the sample audio code i found, which outputs .wav file s on X26. Does a similar sample code exist for the digital output connector X27 on an Apalis iMX6 eval board?
Unfortunately HDA audio is not supported at all by the i.MX 6 SoC so it also won’t work on Apalis iMX6.
Does this problem only exist because the Apalis carrier board has a Realtek HDA ACL898 audio IC? If I were to use an AC97 or I2S audio codec chips wouldn’t I be able to get Digital audio from the iMX6? Is there BSP support for AC97 or I2S audio codecs?
yes. The i.MX 6 SoC can not do HDA.
Assuming you are using Linux:
Yes, we successfully added a I2C Audio Codec to the DAP pins:
I2S BCLK MXM3_200
I2S LRCLK MXM3_204
I2S DIN MXM3_196 SOC -> Codec, playback
I2S DOUT MXM3_202 Codec -> SOC, record
You will of course need to make sure that the codec driver is available in the compiled kernel and the device tree is changed accordingly.
How well the i.MX 6’s SSI supports AC97 I don’t know.
Max
